MMHS Dance
Forum rules
MMHS Dance
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
Re: MMHS Dance
Nice rig and clean setup! Haven't seen you around here in awhile.
Re: MMHS Dance
Hi Bassmonster,
Thanks
I think ever since I have finished my builds, I have been busy pulling together everything for the Business. But, drop in often to view the new post. Lots going on.
LC
Thanks
LC
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
Re: MMHS Dance
Watched your other vid with the laser.. Thing is awesome, but be careful using it in public because I know a local laser guy just had to spend a couple grand showing that his lasers were legal. I love lasers, but the feds are cracking down on them pretty hard lately.
Why can I never make up my mind?
Re: MMHS Dance
Just keep them pointed at the ceiling out of eye line, should be ok
Re: MMHS Dance
I was assuming he knew that, but you have to have a license for anything over 5mW in a public location IIRC. And that is regardless of how you place them.technicaldave wrote:Just keep them pointed at the ceiling out of eye line, should be ok
Re: MMHS Dance
But, we are in the USA, and technicaldave is in the UK. Different laws, rules and rights.Whiterob wrote:I was assuming he knew that, but you have to have a license for anything over 5mW in a public location IIRC. And that is regardless of how you place them.technicaldave wrote:Just keep them pointed at the ceiling out of eye line, should be ok
Re: MMHS Dance
Yeh seems the regs are different. We have ridiculous amounts of health and safety legislation though, so even though you don't need a licence , you're still supposed to limit output in smokeless areas, put signs up around the place, reduce the intensity if there's people influenced from alcohol, use a fat beam or cluster if you can , have it 3m over heads etc.
