Slim THTLP
JensToft91
Slim THTLP
#1 Post by JensToft91 »
Hi all.
The project is a go.
I got my wood sawed by the store - as I thought they could make the cut more precise than myself. Well. Lesson learned. Don't do that.
It's not too bad though, and I believe I can fix the minor issues as I go along.
My biggest problem is, the main plate, where everything attaches to, decided to bend backwards. As far as I can see, there's only two parts that straighten the sides - and they are both in the same end.
Any tips?
JensToft91
Re: Slim THTLP
#2 Post by JensToft91 »
I used a piece of scrap wood, and straightened it out. I placed it in the horn-mouth, so I can remove it when it's finished.
DaveMacKay
Re: Slim THTLP
#3 Post by DaveMacKay »
It depends on how bad the warping is.
  • If the warping is relatively minor, I think that the approach you've taken will likely be OK. Also, adding the panels and other side will help to force the side into shape.
  • However, if the warping is extreme, you may want to discard that piece and cut a new one. I understand that you're looking to keep the cost of the build down, but buying a new sheet of plywood will be less costly than ending up with a bad subwoofer and having to redo it.
Re: Slim THTLP
#4 Post by Seth »
JensToft91 wrote: Wed Jan 12, 2022 12:03 pm Hi all.
Any tips?
Awesome Jens! I didn't expect it to begin so soon. Good for you :thumbsup:
My experience with having the lumber yard cut down sheets is; the equipment is great and very capable of doing a really good job. But, the blade is nearly always dull and the employee making the cuts thinks ½" off is close enough.
Follow the plans instructions for dealing with warpage. As it comes together, it'll straighten out. Honestly, I'd rather have a warp in the sides than in the panels.
JensToft91
Re: Slim THTLP
#5 Post by JensToft91 »
The support I made is working pretty well. I'll post a picture of it when I get home.
I was very clear about the precision at the lumber yard - it was the saw. Most of it is the same width - but some of the boards is narrower towards the end. Like the sheets tilts when the saw approaches the end. Plus, the cuts themselfs are very slightly curved - so the board have the same width thoughout - but is curved "lengthwise". But I believe it's doable.
Couple of pics of the curve attached.
Driver for scale (another 12 inch)
DaveMacKay
Re: Slim THTLP
#6 Post by DaveMacKay »
I think you'll be fine.
Good luck with the build.
Re: Slim THTLP
#7 Post by Chris_Allen »
When you secure the side, you should be able to pull that curve out as long as you secure with screws. If you use a nailer, you might have a hard time getting air tight.
Be careful if you have to cut the curved sheets, it can cause chaos with an angled edge.
JensToft91
Re: Slim THTLP
#8 Post by JensToft91 »
It's starting to take shape! Panel 5 was a struggle. I ruined my saw-sled, because i forgot that the saw was set to a 7-deg angle from the previous cut.
The panel is not super straight - but I'm sure it's airtight. I don't think it will cause any problems :-)
JensToft91
Re: Slim THTLP
#9 Post by JensToft91 »
Chris_Allen wrote: Fri Jan 14, 2022 8:06 am When you secure the side, you should be able to pull that curve out as long as you secure with screws. If you use a nailer, you might have a hard time getting air tight.
I'm using all the screws i feel that's necessary.
How does the curved sheets affect the angled edge? I'm using a saw-sled- so the panel is always pressed flat during a cut. I can imagine the problem on a table-saw though :shock:
JensToft91
Re: Slim THTLP
#10 Post by JensToft91 »
Close-ups
Re: Slim THTLP
#11 Post by Seth »
Looking mighty fine Jens :thumbsup: You're nearly on the home stretch! Nice job.
I'm anxious to hear your report of how it compares to your TT.
JensToft91
Re: Slim THTLP
#12 Post by JensToft91 »
Thanks!
Me too. I'll post side/side measurements when it's completed 👍
I ran out of my PU glue, and went to buy a new one. This one expands a hell of a lot! Now I get why people say "I don't like PU. I makes me puke".
JensToft91
Re: Slim THTLP
#13 Post by JensToft91 »
The driver will arrive in march. So I need a bit of patience though. 🙄
jimbo7
Re: Slim THTLP
#14 Post by jimbo7 »
JensToft91 wrote: Mon Jan 17, 2022 12:11 amI ran out of my PU glue, and went to buy a new one. This one expands a hell of a lot! Now I get why people say "I don't like PU. I makes me puke".
What are you using? Most of us here us Loctite PL glue. It expands some but not anything like a foam does. The smell isn't anything noxious but it will ruin anything it touches.
JensToft91
Re: Slim THTLP
#15 Post by JensToft91 »
It's Danish, so you probably can't look it up.
I have attached a picture of it, where you can see the new (Very foaming) glue line applied outside of the joint to seal it. You can also se a glueline of the old, less expanding glue.
Should I but something else?
