The cabinet is complete!
I spent a fair amount of time cleaning up the PL Premium squeeze-out from the day before, caulking all of the joints so that they have nice smooth fillets, and filing in holes from brads with wood filler.
With that out of the way, I attached the driver chamber rim flange to the three sides that were in place. I then fit two driver chamber braces to each side. Fortunately, I had drawn a circle around the Dayton RSS315HF-4 driver when I had temporarily installed it, so that I could use that circle as a guide, keeping the driver chamber braces clear of it. Happily, I was able to install the braces in their correct orientation by installing them 3" from the sides. It was tight, but everything fit.
Then I fit the second side to the cabinet. It took a bit of finessing to get it to fit just right. I tested with screws to see if the panels were lined up with the lines i drew at the beginning of the build. I'd check to see if I had screwed into solid material, or if I had missed the mark. Most of the lines were in the right places, which made me quite pleased. Having assured myself of the fit, I applied a large bead of PL Premium on all of the panels that would contact side 2, and put the side in place. I used a few screws to ensure alignment, but used 1 1/4" brads for most of the fastening.
With all sides of the THTLP installed, I attached the chamber rim flange to side 2, and installed the last two driver chamber braces.
I checked to be sure the cabinet was square and measured the chamber opening. To my delight, it was spot-on. I then cut the chamber cover to the correct size and installed two braces. Because my THTLP is only 15" wide, the braces could only go one way. They, too, were attached with PL Premium and brads.
Tomorrow, I hope to finish up the work that has to be done in my (unheated) garage:
- scraping off the PL Premium squeeze-out
- trimming panel 8 (which was purposely left too long) so that it is flush with the cabinet
- filling holes with wood filler and sanding the cabinet smooth
Then, I'll move the THTLP indoors.
Although the cabinet is complete, there is still work to do:
- mounting and wiring the driver (Dayton RSS315HF-4)
- installing a gasket on the driver chamber opening
- installing the driver chamber cover
- installing the plate amp (Dayton SPA250DSP)
The plate amp is on backorder and isn't expected to arrive for several weeks so that I'll have to practice patience while waiting to put the THTLP in action.
As can be seen in the photos, the THTLP is bare wood; I haven't put any finish on it. My plan is to veneer it in the spring (when I can comfortably work outside again).
I'd like to thank the members of the forum for their support and encouragement. I'd also like to commend Bill on how clear his build instructions were.
