Page 1 of 7
Things that go boom
Posted: Sun Mar 14, 2021 3:28 pm
by himhimself
Finally making a start on T30 #3 and #4. Other than a few speakon jacks I think I have pretty much everything to make the matching pair. Not much free time, so will be slow. But better late than never.
Re: Things that go boom
Posted: Sun Mar 14, 2021 4:49 pm
by Seth
How wide are you going? Which drivers?
Posted: Sun Mar 14, 2021 5:28 pm
by himhimself
3012LFs at 20" wide, just like #1&2.
Posted: Sun Mar 14, 2021 9:28 pm
Cool. Enjoy your builds!
Should this go in the "Builds" section?
Posted: Mon Mar 15, 2021 8:02 am
by himhimself
You're right, Tom, probably should. Is there a way to move a thread?
Posted: Mon Mar 15, 2021 8:30 am
Bill has the authority, and maybe Chris.
Posted: Mon Mar 15, 2021 9:02 pm
by Seth
...Things that go thump in the night.
Posted: Wed Mar 17, 2021 10:45 am
by himhimself
Need to pick up some fresh plywood blades before I cut the access holes in the side. Got me thinking (dangerous, I know):
I was considering making the access flanges one-piece this time. Any reason not to do that and glue them to the backside right at the start? That would give a nice edge for installing the first panels. As I recall, it was a little bit of a pain to get those positioned and screwed in from the underside. With the flange already there, they could be butted up against it and pinned both to the flange and each other, then just clamped down through the access hole while they cure.
Posted: Wed Mar 17, 2021 10:46 am
by himhimself
Also, Bill, can you can bump this over to the build section? I'll continue to update as these come together. Thanks
Posted: Wed Mar 17, 2021 10:49 am
himhimself wrote: ↑Wed Mar 17, 2021 10:45 am
No reason at all not to do that. I did one-piece flanges on my last T39 build - great alignment tool for other panels and easier than trying to add 'em later.
Posted: Wed Mar 17, 2021 11:25 am
by Chris_Admin
Tom Smit wrote: ↑Mon Mar 15, 2021 8:30 am
Whooooshhh!
Posted: Wed Mar 17, 2021 5:21 pm
by himhimself
Thanks Chris - you have the power
And thanks for the vote of confidence on putting on the flanges first off, Bruce. Definitely going to do that.
Posted: Thu Mar 18, 2021 3:00 pm
by AntonZ
Chris_Admin wrote: ↑Wed Mar 17, 2021 11:25 am
Whooooshhh!
Bill this site's Yoda is.
Chris though is at the controls of the warp engine
Posted: Fri Mar 19, 2021 8:51 pm
by Rich4349
Need to pick up some fresh plywood blades before I cut the access holes in the side...
Freud makes a rather good blade, and not TOO expensive.
Posted: Sat Mar 20, 2021 7:11 am
Freud Diablo are excellent blades at a good price. They're much better than plain steel plywood blades. I use 100 tooth on my table saw, 60 tooth on my circular saw.
