Thanks. Chris. Pics look good, but my skills still need help. I had to improvise. Due to not fully understanding the plans. I know IITP, but with every build their is something new learned. But that means I just need to build more.Chris_Allen wrote: ↑Fri Jun 15, 2018 4:01 am It's a wise move to delay at this point as you need to do all the necessary leak testing. You've done all this work and I wouldn't rush now. Otherwise, the build is looking good. Which handle option did you go for?
About the handles, none due to time crunch. Will be installing recessed wheells and handles as per plans, top and bottom. I am in the process if looking to install some skid guards (skateboard rails) to be made from 1/2" plastic sheet, cut to 1" x 1 1/2" - 35" and 18" strips for back top and bottom. Paint will be cheap flat black 1st coat followed by duratex and corner protectors. Still not set on 1 or 2 connestors. Probably go with back and possibly in the mouth as per plans. Figured I can do a rectangle recess vs the round to place the 1/4" backing plate.
