OT 12 build in Hungary
Lustyik
#1 Post by Lustyik »
Hi all,
I built two OT12 (2015; NSD2005).
Here are some pictures.
I have to say BIG thank you for Bill, Grant, Bruce and DJPhatman. If I had any questions, they helped me immdiately
Bought PU glue are available in EU. After some trial I decided behind Fischer KK. If you are well prepared for fast fixing, KK could save plenty of time, due to quick fixing.
Built: 2x OT12 (2512; NSD)
Ongoing: 2x T39 (3012)
PreSonus sl 16.4.2
Driverack PA
Driverack PX
PKN XD2500 (2x650w / 8ohm)
PKN LC4004 (4x500w / 8ohm)
Lustyik
Re: OT 12 build in Hungary
#2 Post by Lustyik »
Some more pictures...
PreSonus sl 16.4.2
Driverack PA
Driverack PX
Lustyik
#3 Post by Lustyik »
...and more...
I did not read the plan carefully, so I had some extra to do...
PreSonus sl 16.4.2
Driverack PA
Driverack PX
Lustyik
#4 Post by Lustyik »
Close to the end...
PreSonus sl 16.4.2
Driverack PA
Driverack PX
Lustyik
#5 Post by Lustyik »
And the FINISH
The entire project started at 13th of May.
I worked on the cabs untill 16th of June.
I worked at weekends only but at least eight houres each day.
That was my first real woodworking project, I did not have any serious woodworking experience before.
I learned a lot during this jurney about woodworking and my nex cabs would be ready much faster.
I was confused a couple of times due to my week english knowledge. I needed more time sometimes, to get real understanding about the next step. Many posts and mainly pictures here, helped me a lot also.
But if I take into consideration all the thinks, like lack of experience and language issue, Bill's plan must be EXCELLENT! It simply WORKS.
Speakers are wery clear and wery loud and wery light as well.
Warnex painting with structure roller
PreSonus sl 16.4.2
Driverack PA
Driverack PX
#6 Post by Grant Bunter »
Very nice build and finish!
The dowel in your CD horn doesn't look like it is wide enough (in diameter).
You should replace it with the right diameter dowel.
The purpose of that rod is to make it a diffraction rod, to increase horizontal dispersion...
#7 Post by Bruce Weldy »
Very, very nice work!
Now, build another pair and really be blown away.
dswpro
#8 Post by dswpro »
Awesome! way better than my own builds! : )
Charles Jenkinson
#9 Post by Charles Jenkinson »
Nice work. It's fairly obvious that you have a good feel at working with the wood. Well done.
2xT30
Lustyik
#10 Post by Lustyik »
Grant Bunter wrote:Very nice build and finish!
:wall:
Thank you Grant!
You have right. My calculation was wrong. I was (maybe) too tired and finished it after splitted 5/8 (0,6) so I used 6 mm dowel. :mrgreen:
I simply forgot to mutiply it with one inch (5/8 times 25,4 = 15,87mm).
So in this case I can expect even wider dispersion? It is great news.
Thanks again!
PreSonus sl 16.4.2
Driverack PA
Driverack PX
Lustyik
#11 Post by Lustyik »
Final pictures with proper size dowel. :)
I have been using this cabs for one and half years. Clear and very nice sound, good feedbacks from audience.
Very easy to carry, even these are not light versions!
OT12s are hunger for four T39 at least. :)
Unfortunately the most of the time there is not enough place to use more than one T39 in the venue where we play.
I guess my next project is Jack.
Excellent design!
PreSonus sl 16.4.2
Driverack PA
Driverack PX
ACUA
#12 Post by ACUA »
That looks great. And great build too you make it look easy.
Lustyik
#13 Post by Lustyik »
THX ACUA!
Honestly the secret of the success is the solid design and the easy to follow plan.
Even tho I had to recalculate everything to IS. :)
PreSonus sl 16.4.2
Driverack PA
Driverack PX
