Dunavin’s OTop 8 build
J_Dunavin
#1 Post by J_Dunavin »
Start of a very slow build…
No beauty contest here, but will be functional.
Re: Dunavin’s OTop 8 build
#2 Post by Bruce Weldy »
Looks nice.
J_Dunavin
#3 Post by J_Dunavin »
Thanks Bruce!
I’ve got it wired up to the ASDs and Betas for testing.
It makes music 8)
#4 Post by Seth »
Sweet. Congrats on kicking off the new project :thumbsup:
How many tops are you making this time around?
J_Dunavin
#5 Post by J_Dunavin »
Not as many as I’d like 😄
This will be a very small, very mobile, rig. Two tops and two MAYBE four T39s
I loved my six DR six Tuba set up, but never had a chance to use it all together. Just took up too much room.
DaveMacKay
#6 Post by DaveMacKay »
Good luck with the build.
howiez
#7 Post by howiez »
Looks great, I'm about to build crossovers for my DR200's dragging my feet as it'll be no beauty contest winner either!
J_Dunavin
#8 Post by J_Dunavin »
Here's a few pictures, hard to find any time these days, though Spring is around the corner :hyper:
Here i drew a line a line on my cross cut sled, to help me line up a stop block for cutting the CD horn pieces. I also made my original cuts bigger than necessary, so that i could cut up to the line.
Test fit :D
Drawing out the OT8 speaker mounting plate
AND the mail man was nice to me today! worth the wait! Now i wish i would have ordered four...
T_Gowan
#9 Post by T_Gowan »
That pool table will make a nice flat surface to build on. I'm not a pool player so it would work for me anyway lol
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
J_Dunavin
#10 Post by J_Dunavin »
Ha! Indeed it would make for a great build table.
I do play and once in awhile convince the wife to play a few rounds. Somehow she mistakes it for a laundry table 🤔
J_Dunavin
#11 Post by J_Dunavin »
The OT8 plans call for a phase plug extension, these are flat disc. Would there be any advantage to making them similar to the throat filter called out in the DR plans?
I tested various configurations, what's in the plans is what worked best.
J_Dunavin
#13 Post by J_Dunavin »
Will do then, thank you Bill! 👍
J_Dunavin
#14 Post by J_Dunavin »
Working on the CD horn.
I tried to glue everything as straight as i could, but ended up with some unevenness.
Nothing a sanding block can't knock down.
J_Dunavin
#15 Post by J_Dunavin »
Kicking into full build mode now, as i have a gig on the 22md and 23rd :noob:
I'd love to get my T39s done as well, but if i can just get the OT8s done, it'll me a miracle. Which actually, for this gig, will be fine if there are no subs.
Going to try and grab as many pictures as i can along the way.
Just a blank for the CD driver, I did draw out the outline, center hole and mounting holes in QCad and then just used a pic to make the center holes.
Cutting out the holes for the driver baffle.
I know ... way too much extra work here, but i've gone the extra mile and am routering an 1/8th deep slot for the panels to fit into. No weight penalty and will make for a stronger cabinet. ( yes i made the appropriate panels 1/4 longer to accommodate )
