I'm hating having to post/ask this, especially since I've never built my Omni 15TB! Man, having daughters, a historic house to be after, and living paycheck-to-paycheck keeps you a good distance from your own "Happy Place" projects. But, as I would like to do this this year if I can, I thought I'd venture out here...
Is there a mod to the Omni 15 plan, so that it can be built as a 212? I have an Acoustic Control Corp 370 bass head, and it likes to run at 4 ohms. It REALLY likes to run at 2 ohms, but if I could build a 4 ohm cab, I'd be pretty much ruling my small world here.
Is this a thing, or did I just dream it up?
Thanks for your time.
Omni 212?
- Count Bassie
Omni 212?
"Whatever we do, it is what it is, and we do it".
-The Grubs
Trace Elliot AH250SMX
'83 Hamer Cruisebass, modded
Ibanez BTB405M
-The Grubs
Ibanez BTB405M
Re: Omni 212?
Only for the last 12 years or so.Count Bassie wrote: ↑Sat Feb 02, 2019 8:39 pmIs there a mod to the Omni 15 plan, so that it can be built as a 212?
Re: Omni 212?
Bit if a side note here, relative to your question about the Omni 2 x 12, but could you explain why?Count Bassie wrote: ↑Sat Feb 02, 2019 8:39 pmI have an Acoustic Control Corp 370 bass head, and it likes to run at 4 ohms. It REALLY likes to run at 2 ohms, but if I could build a 4 ohm cab, I'd be pretty much ruling my small world here.
My analytical side says 2 ohms loads on that amp produce less voltage than at 4 ohms, (there's only a few volts difference) and raise current output from the amp, essentially working the amp harder than it needs to...
DR 250: x 2 (melded array) with March 2012 plans. 2 more under way with CD horn
WH8: x 3 with melded array.
Re: Omni 212?
A solid state amp will produce the same voltage into any impedance load. If all else is equal, and it seldom is, halving speaker impedance increases sensitivity by 3dB. The downside is that halving the impedance load doubles the current draw on the amp, which the amp may not be happy about. Another factor is that increasing speaker sensitivity via lowering impedance does not increase maximum SPL. That's limited by driver displacement, Vd, which is unaffected by impedance.
Re: Omni 212?
Brings back memories.....my bass player who passed away in 2017 played Acoustic amps way back in the 70s.
He started with a 360 and added a 370 playing through them both at the same time. There really wasn't any PA support back then except for touring acts. He could rumble along with those 100 watt Marshall stacks the guitar players were using.
6 - T39 4-25" 2-22" 3012LF
4 - OT12 2512 Melded/NSD2005
