New Omni 15 Tallboy
jdmrivera
Re: New Omni 15 Tallboy
#16 Post by jdmrivera » Thu Mar 09, 2017 12:57 am
CoronaOperator wrote:Not the outputs but you can convert the line level inputs to mono using one of these:
https://www.amazon.com/Stereo-Mono-Audi ... B00MHKA038
You can use the tape 2 monitor on the receiver (if you have it). Tape 2 out to box inputs, box outputs to tape 2 inputs. Enable tape 2 monitor on receiver.
Looks like this will work with the Yamaha receiver I have.
Maybe a silly question but why do the OTB plans call for two speakon jacks to be installed on the cabinet?
Omni Tallboy 15 w/3015LF (My BBQ music Machine!)
2 Lab 12 T39s 24" Wide
4 OT12s, 2 Melded Array, 2 Flat Array
CoronaOperator
#17 Post by CoronaOperator » Thu Mar 09, 2017 1:02 am
jdmrivera wrote: Maybe a silly question but why do the OTB plans call for two speakon jacks to be installed on the cabinet?
In and out so you can daisy chain more cabinets. Also you can wire tops to the 1+/1- connectors and subs to the 2+/2- connectors and no matter which way you daisy chain your cabinets, using 4 conductor speaker cable they will all get the respective signal.
jdmrivera
#18 Post by jdmrivera » Thu Mar 09, 2017 1:08 am
Perfect. Thanks.
