DR250's or 280's with Tuba 30's
Combining subs, tops and all the rest of your kit.
Paddlsonic
#1 Post by Paddlsonic » Mon Sep 07, 2020 11:26 pm
Hi,
I built a couple of tuba 30's for a mate and man are they amazing!
Now i'm going to build some for myself.
I was wondering opinions on whether the dr250's or 280's might be a better choice to complement the tuba 30's.
Mostly to be used for indoor use (occasional small outdoor things) to take a range from really low end bass/sub sounds and electronic kick drum up to mic'd hihats and effects.
Basically want to capture evenly the whole spectrum.
Any thoughts much appreciated.
Cheers
Re: DR250's or 280's with Tuba 30's
#2 Post by Bruce Weldy » Tue Sep 08, 2020 7:34 am
ahhh....so you've already started another thread.....good.
With only 2 Tubas, you should be looking at either DR200s or OT12s. Smaller and lighter than the bigger DRs and match up better with only two Tubas.
6 - T39 4-25" 2-22" 3012LF
4 - OT12 2512 Melded/NSD2005
#3 Post by Bill Fitzmaurice » Tue Sep 08, 2020 9:11 am
At a 1:1 ratio DR250 match best with T39 or T48, DR280 match best with T48 or T60.
Paddlsonic
#4 Post by Paddlsonic » Tue Sep 08, 2020 6:23 pm
thanks for the replies guys.
At 1:1 would DR200's fit with the tuba 30's?
hooked on the 30's and the DR's.
cheers
#5 Post by Bill Fitzmaurice » Tue Sep 08, 2020 9:05 pm
That would be a good match.
Paddlsonic
#6 Post by Paddlsonic » Wed Sep 09, 2020 4:01 am
thanks guys again for all the advice. I better get those plans ordered , so i can get this thing up and running, cheers
