pa sound system for uptempo hardcore frenchcore tekno and dubstep
Combining subs, tops and all the rest of your kit.
holzboss
#1 Post by holzboss » Tue Mar 17, 2020 3:09 pm
I want to build sound system fro heavy bass music. Also ther bass should be as deep as possible.
I am thinking just for beginning to start with two tubas 60 and 4 dr 200 divided in 2 mid and 2 high,
Or what do you recommend as the top for good low and mid response ?
i want to play mostly uptempo. But also hardcore frenchcore terror and tekno and if possible dubstep and DnD.
How should i set up the amplifiers someone told me to buy 3 amps and an active crossover and someone told to just buy one amplifier.
I just want a small sound system. Upgradeable in the future. in future i will add some tuba 60.
Re: pa sound system for uptempo hardcore frenchcore tekno and dubstep
#2 Post by Bruce Weldy » Tue Mar 17, 2020 3:22 pm
Not sure what you mean by dividing the 4 DR200 in 2 mic and 2 high. Bottom line is that they should all be built the same way and will be EQed and crossed over in the same place.
With 4 Tops you should probably have at least 4 T60s.....especially if you ever want to take it outside.
You will definitely need a speaker processor like a dbx Driverack to provide crossover, EQ, and most importantly for the T60s - limiting.
You will need one amp for the DRs and one for the T60s if you only build 2. If you build more, you'll either need another amp or a more powerful amp.
There are some amplifiers that have 4 channels that could run all the speakers....they get pretty expensive.
Tell us more about what you have already and what your level of expertise is in Pro Sound...
6 - T39 4-25" 2-22" 3012LF
4 - OT12 2512 Melded/NSD2005
#3 Post by Grant Bunter » Tue Mar 17, 2020 3:32 pm
Hello!
Bruce has already covered what needs to be asked initially.
Seems you want a bit of volume capability as well, so the DR250 might be a better choice than the DR200...
T39's: 4 x 20" BP102 , 2 x 28" 3012lf.
WH8: x 3 with melded array.
holzboss
#4 Post by holzboss » Tue Mar 17, 2020 4:11 pm
thank you so i connect it this way speakers to the amplifiers and the amplifiers to the speaekr processor ? or the speakers to the speaker processor and amplifiers to the speaker processor? and is it ok to build just two types of speakers. The sub and the DRs. or will it be better to divide the frequencies to mids and highs or is the DR ok to play mids and highs together?
#5 Post by Grant Bunter » Tue Mar 17, 2020 4:22 pm
Mixer to processor
Processor in to processor out, 1 channel to amplifier for subs
1 or 2 channels to amplifier for tops/mains.
Yes, DR's will do both mids and highs, and they will be fine. No need to have mids boxes, and highs boxes...
#6 Post by Bruce Weldy » Tue Mar 17, 2020 4:31 pm
Obviously, you are new to this...and that's fine. First lesson is signal flow - so that people can help you and understand what you are doing, you should always follow the signal flow when discussing what device goes where.
To reiterate what Grant said:
The sound goes from the source (microphone, CD player, etc.) to the mixer input. Then from the mixer output to the speaker processor input where crossover, EQ, limiting takes place. Then from the HIGH output of the processor you go to the input of a power amp, then to the speakers. From the LOW output of the processor you go to the input of your sub power amp, then to the subs.
Don't ever start with the speakers and try to work your way back....speakers are always last in line.
#7 Post by Bill Fitzmaurice » Tue Mar 17, 2020 5:04 pm
If the OP isn't an experienced woodworker the OmniTop 12 might be better still.
SethRocksYou
#8 Post by SethRocksYou » Tue Mar 17, 2020 7:19 pm
I want to build sound system fro heavy bass music...
Hey man, welcome, I'm Seth. What's your name, where ya from?
#9 Post by Grant Bunter » Wed Mar 18, 2020 3:08 pm
Cheers Bruce,
Note to self, slow down, take the time to explain fully.
True...
holzboss
#10 Post by holzboss » Fri Mar 20, 2020 6:31 am
thank you i will consider the omni top 12. Does it have passive crossover ?
#11 Post by Bruce Weldy » Fri Mar 20, 2020 7:49 am
Yes, it does. It's a great sounding box.
himhimself
#12 Post by himhimself » Sun Mar 22, 2020 7:38 am
+1
2xT30 (20", 3012lf)
4xOtop Jarray
holzboss
#13 Post by holzboss » Sat Apr 18, 2020 12:43 pm
Is the 2kHz crossover point at Omnitop 12 with compression horn driver ok for this kind of use? with the eminence asd 1001 HF. bcs i cant find any f151m 8
#14 Post by Grant Bunter » Sat Apr 18, 2020 5:40 pm
Anyone who is an eminence stockist and is selling the ASD1001 should be able to get the F151M-8 in, depends on price they are asking I guess.
Blue Aran in the UK lists the F151M-8 at about 65 pounds.
But, yes, use the 2K filter in the plans for the ASD1001.
I couldn't find it on Thomman, but did notice some B stock Deltalite 2512's if your building Otops…
#15 Post by Bruce Weldy » Sat Apr 18, 2020 5:45 pm
Only in-stock Eminence items are available as the plant has been shut down during the pandemic. Won't be ordering anything until they fire it back up.
