All in one cherry; center and sub channel
Scott Brochu
#1 Post by Scott Brochu » Fri Dec 09, 2016 8:34 am
I recently just made a combination center channel, TTLP and av equipment entertainment center all in one.
It is made out of cherry with plywood interior wall and back.
Believe it or not my wife likes it without the center channel cover. I like the sleek look with the black nylon fabric stretched.
The nylon is held on my a 1/4"OD plastic hose in a 1/2" deep x 1/4" groove in the door frame. (basically instead of the floating raised panel I put the nylon).
I also mounted the 100watt plate amp in the side above the TTLP sub mouth which is also covered in nylon.
It has a small PC fan in the back sucking out the heat of the XBox one, tuner and cable box.
dimensions; 62"x20"x39.5"tall, sunken false floor for the sub to allow maximum space above.
Drumming is a way of life.
ME LIKE TO HIT THINGS!
Drey Chennells
Re: All in one cherry; center and sub channel
#2 Post by Drey Chennells » Fri Dec 09, 2016 1:49 pm
:clap: very nice ; )
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
#3 Post by Bill Fitzmaurice » Fri Dec 09, 2016 1:56 pm
With the sub down below do the figurines dance? :hyper:
Scott Brochu
#4 Post by Scott Brochu » Fri Dec 09, 2016 3:41 pm
Thank you Drey.
Bill, the figures do not dance because of the rubber feet that tucked between the sub and cabinet.
The bottom is nothing but a grid work of pine 2"x3/4". I new nobody was going to be sliding out the sub but me so no need to cover the whole bottom with ply. Same goes for the top shelf holding center channel.
I don't know why but this sub at 17" internal wide sounds lower than the TT I just took out.
I like having the amp right on the side so I can make minute adjustments.
Gain is at half and the LP is at 90.
Now, I got to make another..... a little bit bigger to house the Left and Right channels. :loler:
#5 Post by Bill Fitzmaurice » Fri Dec 09, 2016 5:55 pm
You should post pictures of that anywhere and everywhere that you can, it's gorgeous.
#6 Post by Tom Smit » Sat Dec 10, 2016 2:12 am
That is a real nice piece of furniture!
#7 Post by LelandCrooks » Sat Dec 10, 2016 7:29 am
That is one fine piece of work Scott.
Scott Brochu
#8 Post by Scott Brochu » Sun Dec 11, 2016 7:56 am
Thanks guys. :D
Which section should I post in the AV forums? Haven't been there in a while.
any other forums that might like this?
#9 Post by Chris_Allen » Sun Dec 11, 2016 3:35 pm
I would post on a gaming forum!
The number of XBox1/360/PS3/PS4 gamers who would love something like that is going to be quite high! I have to concur with the others, it's stunning.
I ran a gaming rig of a 100" projector screen, two T39's and four DR200's and it was simply incredible.
Thinking about markets, there might just be some loving wives who would purchase something like this for their other halves because a) it fits into their room aesthetic and b) their husbands would love it!
A craft fair might be a good place to target.
Again Scott, stunning work - not only is it a beautiful piece (aside from possibly the plate amp in the side) but the form and layout is incredibly clever.
#10 Post by Tom Smit » Tue Dec 13, 2016 11:06 am
Scott, a Huuuuuge Thank You! This has excellent WAF! :clap:
