Just to make shure, Jensen Smooth BS 12N/250A
pahaeno
#1 Post by pahaeno » Thu May 18, 2017 9:30 am
I have these speaker made by SICA, Jensen BS 12N/250A (neo), driver specs are ok, but SPL chart worries me a bit. All those recommended Eminence speakers has quite a peak after 2K, these spekers do have a peak but not that big. "...rising response into the midrange etc."
https://www.jensentone.com/speaker/spec/353
Ok, not ok, possibly, go for it, what?
Re: Just to make shure, Jensen Smooth BS 12N/250A
#2 Post by Bill Fitzmaurice » Thu May 18, 2017 10:27 am
They'll work, but the upper mids will be weak. Compare the chart to a Deltalite II 2512 and it will be obvious why. It wouldn't be much of an issue crossed over to tweeters at 2kHz or lower, but running without tweeters it would be, unless you're running flatwounds and don't care about the upper mids.
