Gluing Piezo Array
nola50
Re: Gluing Piezo Array
#16 Post by nola50 » Tue Jan 10, 2017 2:01 pm
We've decided to bypass Mickie D's as much as possible, even to redirecting the grand children to Chick Fil A instead!
But Mickie D's has all the cool toys! :lol:
#17 Post by Bruce Weldy » Tue Jan 10, 2017 2:11 pm
Bill Fitzmaurice wrote:
dswpro wrote:the PL was washed away by the french fry grease
Imagine what it's doing to your innards. :roll:
Why, it's cleaning them out of course! And everyone wants clean innards, right?
6 - T39 4-25" 2-22" 3012LF
4 - OT12 2512 Melded/NSD2005
nola50
#18 Post by nola50 » Mon Jan 16, 2017 8:39 am
When gluing the array together, what do you put on the wood to keep them from sticking to the jig?
#19 Post by Bruce Weldy » Mon Jan 16, 2017 9:02 am
nola50 wrote:When gluing the array together, what do you put on the wood to keep them from sticking to the jig?
wax paper
whines
#20 Post by whines » Tue Jan 17, 2017 10:53 am
Cling film works too!
nack
#21 Post by nack » Tue Feb 21, 2017 7:12 pm
nola50 wrote:...
While perusing "CA" Glue, I see that there's YouTube videos of a common practice to apply the glue and then baking soda to fill in the cracks. Anyone use that concept?
That is an old luthier's trick for fixing plastic guitar nuts.
nack
#22 Post by nack » Tue Feb 21, 2017 7:16 pm
I use blue painter's tape, but wax paper is probably better.
nola50
#23 Post by nola50 » Mon Mar 06, 2017 7:12 am
The wax paper tears and leaves little pieces.
I'm guessing that unless you have absolutely perfect edges that seal, this is a tough row to hoe.
I'd be interested to know what techniques others are using the trim the Piezos. If I had a CNC machine, that'd be my direction.
:cry: :oops:
#24 Post by Bruce Weldy » Mon Mar 06, 2017 9:55 am
nola50 wrote:The wax paper tears and leaves little pieces.
:confused: How does that happen? If you built the jig, the paper just lays over the top of the jig, then the pieces are laid on the top as they are glued.
Most folks build a table saw jig. Some have used a jig with a circular saw and some a miter saw.
Search the forum - there should be plenty of examples of the jigs out there....there used to be.
nola50
#25 Post by nola50 » Mon Mar 06, 2017 10:02 am
Yes, I built the jig and used it with a fine blade. I might search for a better blade to use on the table saw.
ctmullins
#26 Post by ctmullins » Mon Mar 06, 2017 10:08 am
Documented mine here: http://billfitzmaurice.info/forum/viewt ... 15#p263644
The first array was pretty rough. I cut and glued the second one yesterday, and it's much better. Your cutting technique improves with practice. But I still have glue seeping through to the front side. So that'll be sanded smooth and gone over with a bit of black dye. Worked well for my straight arrays!
-todd
2 x W8 panel-mount
2 x T39 24" 3012LF
#27 Post by Bruce Weldy » Mon Mar 06, 2017 12:13 pm
ctmullins wrote:But I still have glue seeping through to the front side. !
One more compelling reason for using grills with foam. A little more cost, but the inside is hidden and it's a more professional look.
#28 Post by DJPhatman » Tue Mar 07, 2017 1:21 pm
Bruce Weldy wrote:One more compelling reason for using grills with foam. A little more cost, but the inside is hidden and it's a more professional look.
As a plus, it also forces the look-ee-loos to ask you about your wonderfully awesome sounding speakers. Which gives you the chance to tell them you built them (with a sprinkle of pride) and where they can find the plans. Spread the love! :wink:
