Ohm calculation & comparison
Guitar cabs both you and your audience can hear better.
Charles Jenkinson
#1 Post by Charles Jenkinson » Sun Aug 28, 2016 3:58 pm
I need a sanity check on a few numbers please.
If one has a 4x12 cab which is a 16ohm load then that can only have 16ohm drivers in it configured as 2 pairs in series and then those pairs in parallel...?
Now, if one used two of those 16ohm drivers to make an 8ohm 2x12 cab, for the same voltage (knob position) on the amp, the 2 driver cab would be the same loudness as the 4 driver cab...? I've run this on sengelpie audio calculator and the wattage definitely doubles for the same voltage when you half the impedance, ...fairly obvious, so unless someone is running at insane SPL they will be able to achieve the same loudness without needing more of something; by swapping from 4 drivers to 2, if the impedance drops by half anyway.
2xJ12L (3012HO) switchable/melded (http://billfitzmaurice.info/forum/viewt ... 30&t=18773)
2xT30 : http://billfitzmaurice.info/forum/viewt ... 30&t=20386
No sound is better than bad sound.
Re: Ohm calculation & comparison
#2 Post by Radian » Sun Aug 28, 2016 4:40 pm
For starters.....what's the real question here?
Charles Jenkinson wrote:If one has a 4x12 cab which is a 16ohm load then that can only have 16ohm drivers in it configured as 2 pairs in series and then those pairs in parallel...?
or four [4 ohm speakers] in series
Charles Jenkinson wrote:Now, if one used two of those 16ohm drivers to make an 8ohm 2x12 cab, for the same voltage (knob position) on the amp, the 2 driver cab would be the same loudness as the 4 driver cab...?
All fine until you introduced "loudness" into the fold. Loudness can have a relationship to power, but it is not discrete. There's much more to it than that.
Especially where instrument sound is concerned, and particularly guitar cabs.
#3 Post by Bruce Weldy » Sun Aug 28, 2016 7:51 pm
It's a scientific fact that if the cab looks bigger and has more speakers it will be louder....regardless of any other factors.
From "The Guitarist's Guide to Physics"
6 - T39 4-25" 2-22" 3012LF
4 - OT12 2512 Melded/NSD2005
Charles Jenkinson
#4 Post by Charles Jenkinson » Sun Aug 28, 2016 8:45 pm
Radian wrote:For starters.....what's the real question here?
I forgot about 4ohm speakers. :fruit:
Ok, I should have not used the term loudness. What I mean is 'is the approximate 6dB loss from halving the numbers of speakers accommodated by halving the impedance?'
Radian, I know you're one of the best there is at this sort of thing. :ugeek:
Charles Jenkinson
#5 Post by Charles Jenkinson » Sun Aug 28, 2016 8:47 pm
I'd better get a copy of that. Could be handy.
#6 Post by Bill Fitzmaurice » Sun Aug 28, 2016 9:48 pm
The 16 ohm cab will have the same sensitivity as the 8 ohm cab. It's able to go 6dB louder than the 2x12 because it has twice the cone displacement, but it will take four times the power to realize that 6dB.
#7 Post by Radian » Sun Aug 28, 2016 11:05 pm
Charles Jenkinson wrote:Radian, I know you're one of the best there is at this sort of thing. :ugeek:
You won't find me designing my own speakers anytime soon. :wink:
NukePooch
#8 Post by NukePooch » Mon Aug 29, 2016 6:52 am
Wow. I didn't know that. Is it like hot rodding cars where you can add horsepower with the addition of chrome engine components and speed parts stickers? I wonder how many chrome air cleaners you'd need to add to a guitar cabinet to add 6dB?
2 Jack 112 (bought), straight array
Charles Jenkinson
#9 Post by Charles Jenkinson » Mon Aug 29, 2016 7:23 am
Bill Fitzmaurice wrote:The 16 ohm cab will have the same sensitivity as the 8 ohm cab. It's able to go 6dB louder than the 2x12 because it has twice the cone displacement, but it will take four times the power to realize that 6dB.
Thanks Bill
#10 Post by Bruce Weldy » Mon Aug 29, 2016 11:11 am
Thanks Bill
Of course, the reality is that using a 4x12 or even a 2x12 is really overkill 90% of the time.
I ran sound for 4 bands last weekend ...... the loudest guitar player was running through a Fender Blues Junior w/18 watts and a single 12.....and he was still too loud. This wasn't a small place and we were thumping it pretty danged good.
The old days of high powered heads and big guitar cabs is gone - especially with PA support.
#11 Post by Bill Fitzmaurice » Mon Aug 29, 2016 11:24 am
Bruce Weldy wrote: The old days of high powered heads and big guitar cabs is gone - especially with PA support.
+1. I saw Brian Wilson last night, 8000 seat amphitheater, there wasn't anything on stage larger than a 2x12.
