Question about throat horn sides
For unmatched sensitivity.
djtrumptight
#1 Post by djtrumptight » Thu Feb 27, 2020 4:40 pm
I’m in the process of building another set of DR250’s.I cut the throat horn sides at the specified dimensions.After making the angled cuts they now measure at 18 5/8”.Is this a critical measurement and should I make new throat horn sides ? I’m using the older DR250 plans since I already have 4 of those.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
Re: Question about throat horn sides
#2 Post by Bill Fitzmaurice » Thu Feb 27, 2020 4:52 pm
I don't have the old plans, so I can't help.
djtrumptight
#3 Post by djtrumptight » Thu Feb 27, 2020 4:57 pm
By old plans I mean the ones that were available in December of 2009
2 SLA HT systems
2 SLA Pro's
#4 Post by Grant Bunter » Thu Feb 27, 2020 5:02 pm
The plans from March 2012, and the plans prior to that, both say that the height after making the angled cuts should be 19 3/8".
What do your plans say?
WH8: x 3 with melded array.
djtrumptight
#5 Post by djtrumptight » Thu Feb 27, 2020 5:46 pm
Grant mine says the same thing but that’s in regard to the outer face of the throat horn supports,I’m good on that part,they are 20” before trimming with the 3 degree angle,my problem is the throat horn sides that were 19 1/2” before I cut the angles.After cutting the angles as u can see from the picture they are roughly 18 5/8”,I’m just wondering if that is a critical measurment
2 SLA HT systems
2 SLA Pro's
#6 Post by Bill Fitzmaurice » Thu Feb 27, 2020 6:04 pm
Not necessarily critical, but it will cause the cab to have a bit more angle to it.
