Driver wanted...
For unmatched sensitivity.
Starchild
Driver wanted...
#1 Post by Starchild » Thu Oct 10, 2019 12:38 pm
Me again, I got 2 DR250s and 4 DR280s under construction and was wondering if this is an ok substitute driver unit. :fingers: https://soundstream.com/product/sct-340/
Re: Driver wanted...
#2 Post by Bruce Weldy » Thu Oct 10, 2019 1:22 pm
There is not much in the way of specs for that thing. In one spot it says 100watts RMS and in another (on the same page) it says 50 watts max.
I'm guessing it's a cheap Chinese Eminence knock-off. Based on the lack of good info, I'd be concerned trying to use the 1.2khz crossover....
I'd try to find something better or use the 2khz crossover.
6 - T39 4-25" 2-22" 3012LF
4 - OT12 2512 Melded/NSD2005
Starchild
#3 Post by Starchild » Thu Oct 10, 2019 2:00 pm
I did send an email to the company requesting the t/s parameters but until I get a reply this is all I got,
Frequency Response-1.5kHz-20kHz
Efficiency (1w/1m)104dB
#4 Post by Bruce Weldy » Thu Oct 10, 2019 2:15 pm
With no size or weight specs, you don't even know if it will fit physically in the cab. Although it looks like a typical ASD1001 screw on....but, hard to tell with no frame of reference.
#5 Post by Bill Fitzmaurice » Thu Oct 10, 2019 3:39 pm
That company probably just slaps their own label on cheap Asian gear and doesn't actually have any expertise. A sure giveaway is that they say 'Efficiency 104dB'. Efficiency isn't stated in dB, sensitivity is.
Starchild
#6 Post by Starchild » Thu Oct 10, 2019 4:22 pm
I got one here, it's magnet diameter is 4 inches, very small and Same threading for the screw on as the ASD's
Starchild
#7 Post by Starchild » Thu Oct 10, 2019 4:27 pm
#8 Post by Bruce Weldy » Thu Oct 10, 2019 4:44 pm
I'm sure it's hard to find quality components where you are, but I'd try to stick with Pro Audio stuff and not these car audio guys. That driver is recommended to cross at 2500hz....the diaphragm is small.
Starchild
#9 Post by Starchild » Thu Oct 10, 2019 5:52 pm
The diaphragm and recommended crossover is same as the ASD... For comparison http://www.usspeaker.com/Eminence%20ASD1001S-1.htm
#10 Post by Grant Bunter » Thu Oct 10, 2019 8:01 pm
Hey!
The ASD 1001 is only for the DR250.
Please don't think for a second that the ASD will work sufficiently in a DR280 though.
The HF CD horn in a DR280 is for 2 x NSD2005. They are no longer available;
viewtopic.php?f=2&t=25248
WH8: x 3 with melded array.
#11 Post by Bill Fitzmaurice » Fri Oct 11, 2019 7:27 am
And a Nissan Versa and BMW 340i are both cars. :bash:
Don't even think about using generic drivers from unknown sources. You may not be able to get Eminence, but you should be able to get an Eminence equivalent from one of a dozen other major manufacturers with recognizable names.
#12 Post by Seth » Fri Oct 11, 2019 1:14 pm
The DR280 Plans wrote:A 2kHz crossover diffraction compression horn driver option uses two
Eminence ASD-1001 HF drivers (or the equivalent, with maximum resonance 1.3kHz)...
:slap:
#13 Post by Seth » Fri Oct 11, 2019 1:35 pm
Starchild, what part of the Caribbean?
#14 Post by Grant Bunter » Fri Oct 11, 2019 3:23 pm
:slap:
Bugga, that's what goes with making comments based on older plans.
Still, wouldn't have thought 2 x ASD's would keep up with the mid driver in a 280...
#15 Post by Seth » Fri Oct 11, 2019 6:10 pm
The DR280 Plans wrote:The higher output capability of the
NSD option is best utilized with upgrade woofer.
:thumbsup:
