DR250 or...?
For unmatched sensitivity.
Robin Dobbie
DR250 or...?
#1 Post by Robin Dobbie » Wed Mar 20, 2019 11:52 am
Talking on the PE forum, Bill steered me away from the DR300, which was a good thing, I think.
The description of the DR250 suggests options: drivers, hardware... Just trying to figure out the maximum SPL one could achieve with a DR250 that's got the 80hz tuning?
Re: DR250 or...?
#2 Post by Grant Bunter » Wed Mar 20, 2019 2:42 pm
G'day and Welcome to the forum Robin :)
Because there are options, there's no straight answer.
IIRC, the SPL chart is based on the 2510 and CD's, and you could probably add around +20db to the baseline trace, maybe a tad more, for max volume.
Having said that, it will distort if pushed that hard. If you need to push it to max volume, then you need more than 1 cab per side...
WH8: x 3 with melded array.
Re: DR250 or...?
#3 Post by Tom Smit » Wed Mar 20, 2019 10:39 pm
Welcome to the forum!
+1 to what Grant posted.
Robin Dobbie
Re: DR250 or...?
#4 Post by Robin Dobbie » Thu Mar 21, 2019 5:14 am
Alright, good to know. Yeah, if we do it, I was thinking a pair per side, to start off with.
Re: DR250 or...?
#5 Post by CoronaOperator » Sun Mar 24, 2019 8:13 pm
I had 1 dr250 a side doing an EDM show crossed over to subs st 100hz in a room that can hold about 100-150 people. The UK DJ's cranked it during their set and it was way too loud even for the young folks. I pulled out my spl meter and was reading 117 dBA 25-30 feet away from the cabinets. I dont mind 135 dB's of bass (dBC), but mids and highs above 105-107 dB's (dBA) is painful and no doubt causes hearing damage. It was quickly turned down however it was still absolutely crystal clear at that level. For their size they are some of the loudest boxes you will find.
