This on board amp from Parts Express looks good, at a price that makes sense.
https://www.parts-express.com/dayton-au ... h--300-798
It could be mounted on just about any of our full range cabs with minor modifications. With DRs the logical method is on the back, using a small extension box mounted there. It has enough power to drive a pair of cabs, so it would be easy enough to install a 4 pole Speakon on the cab containing the amp and one on the extension speaker. Full DSP that includes crossover, EQ and limiting plus Bluetooth makes this a very attractive rig.
On Board Amp
Re: On Board Amp
Love that DSP!
I wonder if they are using eGaN FET or MOS FET?
I expect someone to dip their toes in the water and report back
Re: On Board Amp
Would I still have to use a crossover made by me or speakerhardware.com , er something like that?
Defy the vortex -of mediocre-second rate bass- produced by mongrels- devoid of taste!
A beautiful lyric from : Maggotron "In Search of a Funky Khan"
4 T60 27" lab15,Omni TB 2 BP102,AutoTubaMCM 10"
Re: On Board Amp
No, there's plenty of DSP to achieve a good crossover. But, if you want to drive two speakers with it, you'll need to use NL4 connectors and 2 Pair speaker cable to get the highs and lows to the other speaker.....
