Diffusion rod
For unmatched sensitivity.
DJStubbs
Diffusion rod
#1 Post by DJStubbs » Fri Oct 06, 2017 10:48 am
What's it's purpose. I've been seeing it talked about and I honestly don't have any left on my 280s are they super necessary?
10x Tuba 60 - Dual 12" LAB
5x DR280 - Melded 22 piezo array
2x Crest Audio 5.0
1x Peavey IPR2 3000
https://ibb.co/e0Uazv
https://ibb.co/bUxmJQ
Klarity Audio & Lighting
https://www.facebook.com/KlarityAudio/
Re: Diffusion rod
#2 Post by Grant Bunter » Fri Oct 06, 2017 6:36 pm
DJStubbs wrote:What's it's purpose. I've been seeing it talked about and I honestly don't have any left on my 280s are they super necessary?
The diffusion rod increases horizontal dispersion to 120 degrees.
120 degrees is wider than most anything out in the commercial world.
It's an essential part of the melded array, so yes, it is super necessary.
If it wasn't, it wouldn't be in the plans...
DR 250: x 2 (melded array) with March 2012 plans.
T39's: 4 x 20" BP102 , 2 x 28" 3012lf.
WH8: x 3 with melded array.
DJStubbs
Re: Diffusion rod
#3 Post by DJStubbs » Fri Oct 06, 2017 8:54 pm
Well they have came undone and fallen out so I guess I'll try and find a replacement.
2x Crest Audio 5.0
1x Peavey IPR2 3000
Re: Diffusion rod
#4 Post by Grant Bunter » Sat Oct 07, 2017 3:01 pm
DJStubbs wrote:Well they have came undone and fallen out so I guess I'll try and find a replacement.
Good plan 8)
Re: Diffusion rod
#5 Post by DJPhatman » Sat Oct 14, 2017 10:22 am
You can get 1/2" ID PVC at any home and hardware store. Just give it a quick sanding with fine sandpaper or emery cloth, glue it on and paint to match.
