Extension, SPL, perceived sound and possibly more subjects?
Re: Extension, SPL, perceived sound and possibly more subjects?
Look at it this way. You're in a rowboat using a pair of pool cues for oars. You'll get where you're going eventually, but those pool cues can't grab enough water to do the job effectively, no matter how fast you row. That's a direct radiator. Switch to a good pair of oars and you go a lot faster, while doing less work, because they grab the water so much better. That's a horn.
- Chris_Allen
You should put that on the sales page!Bill Fitzmaurice wrote: ↑Sat Jan 01, 2022 9:57 pm Look at it this way. You're in a rowboat using a pair of pool cues for oars. You'll get where you're going eventually, but those pool cues can't grab enough water to do the job effectively, no matter how fast you row. That's a direct radiator. Switch to a good pair of oars and you go a lot faster, while doing less work, because they grab the water so much better. That's a horn.
I spit my coffee out when I read this.Bill Fitzmaurice wrote: ↑Sat Jan 01, 2022 9:57 pm Look at it this way. You're in a rowboat using a pair of pool cues for oars.
....and so it is!Chris_Allen wrote: ↑Sun Jan 02, 2022 11:08 amYou should put that on the sales page!Bill Fitzmaurice wrote: ↑Sat Jan 01, 2022 9:57 pm Look at it this way. You're in a rowboat using a pair of pool cues for oars. You'll get where you're going eventually, but those pool cues can't grab enough water to do the job effectively, no matter how fast you row. That's a direct radiator. Switch to a good pair of oars and you go a lot faster, while doing less work, because they grab the water so much better. That's a horn.
Great analogy!
