The start of my BFM DJ rig
Well here it is roughly a year since I first bought my drivers from Mr. Langford (thanks larry)
Two OT 12's and the first of 4 24" wide t30's.
I am having a blast building now that I have figured things out
I played the OT's in the spare bedroom at low volumes and they sound incredible
Guess I did something right
Awsome designs Bill!!!
Pic added of subs
Pic added of subs
My initials are in the view finder of every camcorder (REC)
2xOT12(Deltalite 2512 loaded, w/melded arrays)
2xOT12(Deltalite 2512 loaded, w/flat array) "In Process"
4xT30(24", 4012HO loaded)
1xAT
1xAT
- RubiconProSound
- Location: Pollock Pines CA. (between Lake Tahoe and Sacramento...)
Re: The start of my BFM DJ rig
Sounds familiar, I also run two 24" T30's ... what are you loading the T30's with?
Built so far:
- Chris_Allen
Not to sound like a party pooper, but the first horn section below the driver appears to taper at too steep an angle.
Not necessarily. That section is technically the throat chamber, so the taper there isn't critical.Chris_Allen wrote:Not to sound like a party pooper, but the first horn section below the driver appears to taper at too steep an angle.
whew......got scared there for a second!
I think that are right anyway, definitly built per plans
I will be uning the 4012HO drivers in the t30's
1xAT
1xAT
What's the reason for your choise?rec wrote: I will be uning the 4012HO drivers in the t30's
If you havn't already bought the drivers go for the 3012LF instead, they will go louder than the 4012HO.
-2 T48 3015LF
-2 DR250 2510 crossfired
- bitSmasher
It's in the (first) post?rec wrote:Well here it is roughly a year since I first bought my drivers from Mr. Langford (thanks larry)
I bought my drivers long before the 3012LF's came out, or the talk of how sweet the titian 48 is for many different applications.
I based my original decision on the fact that Bill recommended the tuba's for recorded music and that is all I will ever play. I have zero
musical ability's. So I went with the top of the line driver (at the time), I am sure that the t30 with the 4012HO will probably do everything
I need and then some.
1xAT
1xAT
Here are a couple of more pics of my progress. I actually have the box seal up and the driver mounted.
Hooked it up in the spare bed room and was quite impressed, I had several things vibrate off of the top shelf in the closet.
I cant wait to get the second one built and see what a pair sounds like. I have to take the driver cover off and counter
sink the holes, glue in the final two braces and put a finish on the cab. I have to admit that when I was installing the driver my hands were
shaking with excitement. It has been a long road but well worth the end result. I have three more t30's
to build and 2 more OT12's........for now. I cant quit thinking about the other designs, so I guess I have the
BFM addiction too.
BFM addiction too.
1xAT
1xAT
First half of the rig is finished....whew!
- Attachments
- 100_0231.JPG (67.3 KiB) Viewed 2117 times
1xAT
1xAT
wow, those are looking nice! im starting my build of two 24" t30's next week and i hope the come out looking as good as yours! let me know how they sound
george
george
2 OTops completed
2 Tuba30's Delta 12LF
2 more on the way OR 4 T48's
Thanks George, I am pretty proud of my build.
The sound is amazing. I have used them in a gym 3 times and I have more bass than I need
and the tops are crystal clear.
I have two more of each in the works. You will be very happy!!
1xAT
1xAT
Can you make a video of your rig and upload it on youtube (Or send me)? I'm very very very interested about the tuba 30!!!
Have:
2x FBT Jolly8ra (active)speakers (100-20.000Hz)
1x Voice System SUB VS8 (active)subwoofer (55-100Hz)
1x MTH-30 (RCF LF12G301)
Geko, I will see what I can do the next time I set up
1xAT
1xAT
