Hi all,
I have a Matamp 50 watt all-tube amp that I love for bass guitar, and it can get quite loud, but it's obviously not loud enough for many applications. (e.g. - loud rehearsals, gigs without PA support, etc.)
I prefer a warm, round, "wooly" bass tone, so I don't need super hi-fidelity, but I do need volume. I was hoping some of you could suggest the best cab or cabs to get the most decibels out of the 50 watts I'm working with.
Thanks and cheers from "beautiful" Baltimore, MD!
Getting Max Volume from 50 Watt Tube Amp?
Re: Getting Max Volume from 50 Watt Tube Amp?
Ohm rating of that amp? Do you like deep lows or more of a classic sound? Size/ weight limitations?
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
The amp has a 4 ohm tap and dual taps for 8 and 16 ohms respectively, so I can be pretty flexible. Size and weight aren't considerations.wallywally wrote:Ohm rating of that amp? Do you like deep lows or more of a classic sound? Size/ weight limitations?
As for my tonal preferences, I much prefer a "classic" bass tone. Think P-bass plugged straight into an angry sounding tube amp.
Your choices would have to be jack or omni full range. You might omit the tweeters. There has been the odd bit of discussion about tweeters not handling raw valve distortion. There's probably a few extra dB in an omni over jack sensitivity if you can be bothered lumping it around.
Two J10. You need the extra sensitivity of using two woofers.
Thank you, sir. Much appreciated. Two J10s it is!Bill Fitzmaurice wrote:Two J10. You need the extra sensitivity of using two woofers.
