For the 8" woofer I take it?Brew wrote:More than enough. My amp rating is a little higher, but the TT replaced 2 subs running a plate amp rated at 500 watts
I've run into one potential obstacle though. My amp is rated at 90W at 8 ohms. The 2nd room outputs aren't detailed anywhere I can find in the manual, so I assume they are the same (or less wattage/more impedance). I don't think you are supposed to power a 4 ohm speaker with it. It's an Onkyo TX-SR606 if I haven't said that already; if anyone knows anything about it, specifically.
Of course I'm still on the fence about whether or not to build an 8" or 10" version. On the one hand 8" is probably enough for normal people , and it would be great to be able to say "This powered sub cost $225 and uses an 8" driver. How's your $1,000 Klipsch 12" working out for you? " - but on the other hand... for about $150 more I could have the 10" and from what I understand some pretty good headroom to push it as far as I want without feeling like I could use more bass.
I haven't come across any technical comparisons between the 8" and 10" TT; how similar are they in SPL? I know the description page says they are about the same in terms of response. Is it worth it to go 10", or will I not notice the difference unless I were to listen to each side-by-side?
