I want to thank everybody for their advice, and let you know I just bought plans for the omni12 tallboy. I think it will be suitable.
If this has been answered elsewhere, I apologize, but would it be possible to load the omni12 with both the delta 12LFA and the BP102, like the 210 version?
Having one 4ohm cab would help me milk the most out of my amp, but if it's a bad idea, I'll look for another use for the BP102.
warning! really long post
Re: warning! really long post
AFAIK, I dont think you can do that. The dual bp102 cab is wired in parallel, and the lower power handling of the bp, as well as different response patterns for the 2 drivers will keep you from doing it in that manner.
Even if you can do it, you are limited down to the juice the bp102 can take... which is about half that of the delta, which would be limiting you regardless of amp output. The bp102 is pretty cheap, and you could probably find someone to trade straight up for your delta here, but hell if I know.
Thanks sine, I didn't think about the power issue.....duh...
