I was reaching for a box on the top shelf of a closet and my DBX PA+ that was in it fell out and onto the hardwood floor. I dampened the shock slightly with my bare foot (the physical pain was way less than the emotional pain). It still bent the aluminum faceplate some and the rotary-knob shaft has a bend. The faceplate is mostly straight now and the knob still works but the it rubs.
So I took it apart and it seems like a it'll be pretty easy to remove and solder a new one on. The question is should I send it in to Harmon, order the part from Harmon, or check Mouser for a similar pot? I already emailed Harmon and waiting for a response.
It's a spare unit, so not a big deal or priority. I just bothers me knowing it was in perfect condition and now it's sitting in a dark scary closet with battle wounds.
Replacing electronic parts
Re: Replacing electronic parts
If you know the value and taper there's no need to involve Harmon.
If it works, don't do anything to it. As long as it turns and the "push" switching works - leave it alone and use it the way it is.
You could end up screwing it up just for aesthetics.
- Rune Bivrin
That's very likely not a potentiometer in the traditional sense, but rather a rotary encoder. They don't really have a value as such, but can be had cheaply: https://www.amazon.com/s?k=rotary+encod ... ush+button
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
