- Hook up multimeter to the speaker leads from the amp (without speaker)
- Set to AC
- Play a tone around 50 or 60hz
- Set amp to max, push up fader, volts should be over 60V
- Increase limiter setting until output drops to 50V (what I am using as max for 3012LF loaded T30s
- Set to AC
Setting voltage limits
I finished my breakout panel and wired the sub cable to take the +1/+2 from the amp and send it to +1/-1 on the panel so I can bridge my Crown. Obviously I'll need to reset the limiter on my PA2 accordingly. Can you please verify my steps as follows;
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
Re: Setting voltage limits
Set your master fader to unity and bring up the volume of the tone via a channel until the output on the board is just hitting unity on your meter. Then check to see what voltage the amp is putting out and adjust the limiter until it gets down to 50. Then, while watching the volt meter, slam the master fader all the way up - if the volt meter stays at 50 then you know you've set it correctly.himhimself wrote: ↑Fri Jul 05, 2019 10:07 am I finished my breakout panel and wired the sub cable to take the +1/+2 from the amp and send it to +1/-1 on the panel so I can bridge my Crown. Obviously I'll need to reset the limiter on my PA2 accordingly. Can you please verify my steps as follows;
- Set to AC
One question I have - wouldn't the frequency from the tone generator influence the voltage? My app can sweep the frequencies. Would it make more sense to set a slow sweep back and forth between 35hz and 70hz just to be sure I didn't select a single frequency that may not give the max voltage output?
As far as the frequency.....remember that voltage is voltage. The frequencies that you sweep will all have a different impedance so that wouldn't tell you anything or be productive as far as limiting. So, just set it on 60hz and leave it.
Oh, and be sure and turn off the AFS if it's on. It will see the tone as feedback and kill it. Ask me how I know......
