Loctite PL Premium in Australia
Re: Loctite PL Premium in Australia
#46 Post by Bill Fitzmaurice »
Leviathanbaph wrote:Just to let everyone know, don't order from budgetgroup if you are in a rush, i placed my order 76 days ago over the phone and still have received no product, have called them many times and simply receive an answer of "it's coming soon"
Order was one box of the PL premium, minimum order; pretty poor service if you ask me.
It's typical that they'll have a minimum order, perhaps a dozen boxes, so they have to wait until enough people place orders with them before they will place an order with their supplier. IME if they don't have it in stock don't bother ordering, look elsewhere.
#47 Post by Grant Bunter »
Bill Fitzmaurice wrote:It's typical that they'll have a minimum order, perhaps a dozen boxes, so they have to wait until enough people place orders with them before they will place an order with their supplier.
+1
Bill Fitzmaurice wrote:IME if they don't have it in stock don't bother ordering, look elsewhere.
Hence the reason for this thread. Budget group are the only source in Australia AFAIK who "stock" PL premium.
You might like to contact loctite Australia:
http://www.loctite.com.au/loctite-Austr ... ealand.htm
And see if PL premium is available anywhere else here, including Adelaide.
If you find other sources by doing that, please list them in this thread...
TrevorMag
#48 Post by TrevorMag »
I have not tried either Locktite PL or Selleys Liquid Nails Platinum, but I have used Selleys Aquadhere Durabond:
http://www.selleys.com.au/adhesives/con ... -durabond/
The pictures below show its runniness, fizziness and what cured squeezeout looks like.
It sands perfectly.
Squeezeout
Squeezeout
Fizzy
Fizzy
Runny
Runny
#49 Post by Bill Fitzmaurice »
TrevorMag wrote:I have not tried either Locktite PL or Selleys Liquid Nails Platinum, but I have used Selleys Aquadhere Durabond:
It sands perfectly.
That looks like what's called Gorilla Glue here, and it's nothing like PL. PL is very thick, applied with a caulking gun, and resembles the consistency of caulk. I've tried Gorilla Glue, PL is far superior.
TrevorMag
#50 Post by TrevorMag »
Bill Fitzmaurice wrote:I've tried Gorilla Glue, PL is far superior.
Fair enough. While I have no concerns about joint strength if correctly applied, the runniness makes is suitable for applying to horizontal surfaces only.
Harley
#51 Post by Harley »
TrevorMag wrote:...the runniness makes is suitable for applying to horizontal surfaces only.
Make that 'perfectly level horizontal surfaces only'.
TrevorMag
#52 Post by TrevorMag »
Harley wrote:Make that 'perfectly level horizontal surfaces only'.
Yes, but I think this belongs in its own thread: "Oven paper, an essential prerequisite" :lol:
Icecake
#53 Post by Icecake »
Harley, since you have been using Sika products, do you think Sikaflex 221 can do the job to build any of the BFM designs?
How about Bostik the 'sausage like' PU adhessive ?
horst
#54 Post by horst »
Icecake wrote:Harley, since you have been using Sika products, do you think Sikaflex 221 can do the job to build any of the BFM designs?
The crucial part is that it expands while curing, this probably doesn't.
#55 Post by Grant Bunter »
Heads up.
Budgetgroup is no longer supplying PL premium.
Forum member Chamesy has discovered another source though (thanks mate).
http://www.abcadhesives.com.au/adhesive ... adhesives/
#56 Post by Seth »
Just a thought... it might save some people a bit of time if you edit that info into post #1.
#57 Post by Grant Bunter »
SethRocksYou wrote: Mon Oct 14, 2019 3:56 am Just a thought... it might save some people a bit of time if you edit that info into post #1.
Cheers!
Chamesy
#58 Post by Chamesy »
Wow this thread is heated haha.
Unfortunately PL Premium is not available by the tube AT ALL anymore only by the pallet load to industrial customers through special order, the folks at http://www.abcadhesives.com.au/adhesive never got back to me and I contacted www.henkel.com.au the distributors of Loctite to Australia and New Zealand and this was their reply:
Unfortunately, since the closure of Masters the availability of Loctite PL premium went from readily available to brought in by special order only.
So now it is only brought in by the pallet load for industrial customer. There is no one selling it by the tube.
OUCH!
So if we want to get stuff locally now we are going to have to find a worthy alternative
PEACE
#59 Post by Grant Bunter »
I called Chris at abcadhesives.
He's confirmed the above.
He recommends Unobond as a replacement. Or get PL in from the USA...
jeremydta
#60 Post by jeremydta »
Well I just ordered a box from Amazon US. Then it came to my door a couple of weeks later.
