THT's and dubstep
Re: THT's and dubstep
One more thing:
Tie-strap tops down when stacking.
One of my otops took a dive during Saturday's show - tweeter array is split in half (fixable) and I'm sure when I open it up the crossover will be damaged, as I can hear some rattle when moving it.
The stack was away from any people, but I'm still glad no-one got hurt...
Another reason to have rubber feet installed. I usually use pole mounts, but there was just no room for a stand.
-More to come!
-More to come!
- Dave Non-Zero
Ouch on the van, and ouch on the otop! My van died last week, so bad to get last minute rental. Damn that eats into the profits.
always strap stuff to something!
I'll tell you what's more of a bitch, 2am loadout in the rain. Then having to get up and load the van out again, into my broken van in the morning to get the hire van back by 9am. (in the rain again)
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Try doing a load out at 1-2:30 AM, in a Tuxedo, in a blizzard with the wind-chill touching -35 degrees F! The bitch don't even show up!Dave Non-Zero wrote:I'll tell you what's more of a bitch, 2am loadout in the rain. Then having to get up and load the van out again, into my broken van in the morning to get the hire van back by 9am. (in the rain again)
Damage report:
The otop has a broken crossover.
Both coils have become unglued, and one has a broken solder joint. A cap also has a broken lead.
Completely repairable, but should have never happened. Rest of the cab looks to be fine.
-More to come!
-More to come!
SeisTres wrote:congrats monomer. Do you plan on getting kick bins for the system? or are you just going to run subs and tops?
What's a kick bin? I thought tops and subs were a complete system?
They are, but some people prefer to run four way systems and some even five way systems. Subs covering anything less than 50-60hz, then kickbins come in which cover anywhere from 150hz-400hz, then the mids and tweets. However, the five way system splits the mid/tweet into mids, highs and super highs.bean438 wrote:SeisTres wrote:congrats monomer. Do you plan on getting kick bins for the system? or are you just going to run subs and tops?
me? i'll keep the piezos the mids and subs, nothing more.
very very interesting...
All this time I didn't realize you were using THT's. I think I'd really like to hear a pair! (or four or eight).
Generally speaking my DJ work does not require such extension, but for me personally I think I would really enjoy that. The T60 is just plain impractical for me...but I could see a pair of 24" THT's being manageable.
I might have to build one for my home theater and see what this is all about. I've currently got 2 powered Polks in there, each with an on board 2000 watt amp.
facebook.com/wisounds
Bill Fitzmaurice wrote:If one wants to try something else, well, that's what DIY stands for.
heh heh, yup. I don't play dubstep/DnB (though I've been known to throw a remix or two in just for my own enjoyment), but knowing what it's *supposed* to sound like has me wishing my rig was @ that same kind of levl. It's a different kind of "sub to tops" ratio thing that people who listen to top 40 or country or rock can't really comprehend....until they hear it.
My perspective on bass changed in 2001(?) @ "Turned On 2" in Madison, WI. The main rig consisted of a stack of subs literally 12 feet high and 75 feet wide. I've heard "a million watts" thrown around in reference to that night but I have no idea if its accurate. It was insane. I've been chasing that experience ever since. Granted I won't be driving a semi tractor to gigs anytime so I wouldn't mind something on a more practical pack size scale
What did happen to wi? did he ever the project started?
This thread gives me goosebumps
PRODUCT IDEA : Speaker Placements for Rooms of Various Shapes & Sizes : A Video Series / YouTube Channel
School, and lots of bowling (I presume)SeisTres wrote:What did happen to wi? did he ever the project started?
He's designing "The Dubhorn" using a TC sound driver. Also designing the Wiarray. I've heard a couple of the boxes, and they sound great!
The THT's are getting torn apart and checked for leaks and loose braces. I have a gig here in Detroit on Christmas, they want all six fired up indoors. I'll be powering them with a mackie5000 in stereo mode, three per side. Should be loud!
-More to come!
-More to come!
Is it a dubsmas party ??
If so I may just make it out for the holiday ... I'll be within a couple of hours of Detroit
Also ... did you ever pair any omnitop 15's with those THT's ??
I'm in the process of getting together a build and after reading this thread won't be building the 12's for fear of the mids missing ...
- Drey Chennells
metaverse wrote:Also ... did you ever pair any omnitop 15's with those THT's ??
Metaverse, running a THT without the access panel creates a massive dip from 75-120hz. and response below 38hz dives.. this graph of the THT with no cover tells the story.. with the panel as designed..
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
InfraCoustik
Free field measurements of the actual cabs indicates a deeper response, with the null at 90hz.Drey Chennells wrote: Metaverse, running a THT without the access panel creates a massive dip from 75-120hz. and response below 38hz dives.. this graph of the THT with no cover tells the story..with the panel as designed..
There are graphs, I just can't find them.
As for me:
I have been bowling a ton recently, going back to school, and snow skiing.
I successfully prototyped and tested a pair of WiRay10 tops, Monomer has heard them. Ran out of money and had to shelve the project.
The Dubhorn is an 18hz corner horn with a 10" driver, a 6 pack will take 3kw and do 140db 18hz up corner loaded.
Both the Dubhorn and WiRay project are on hold until I get the funding to continue.
