What drivers can I use?
Frequently asked questions and the answers to them.
Moderator: Bill Fitzmaurice
Locked
#1 Post by Bill Fitzmaurice »
Every plan contains a list of recommended drivers, and T/S specs so that you may choose from other options. If after checking the T/S specs you still have a driver question you may post it, but you must include a link to the manufacturer's driver data sheet, showing the driver specs and SPL chart. No link=no recommendation. If the manufacturer has no data sheet chances are the driver isn't worth considering anyway.
Please do not ask "Do you have a cab I can use my driver in?". When choosing a cab your priorities are frequency response and cab size, so that's what you base your choice on. You then use a driver with appropriate specs. If you happen to have one on hand fine; if not, buy one. Trying to make use of an on hand driver to save a few bucks and ending up with a cab that doesn't meet your needs is a bad idea.
Locked
