Running tubas
DJStubbs
Running tubas
#1 Post by DJStubbs » Sun Nov 25, 2018 11:42 pm
I’m sure it’s been said before. But when you run a series wired tuba daisy chained to another tuba does the voltage increase? I have my amps set at 70v rms and 80v max per channelis that sufficient? I know it’s not logical to run 2 different lab12 woofers but it is what it is for now until I can change them. I run qsc pld4.5 usually. Sometimes 1 tuba per Channel and often 2 tubas per channel. Thank you!
18x Tuba 60 - Dual 12" LAB
6x Renkus Heinz ST6
1x Lab Gruppen PLM10000Q
2x QSC PLD4.5
2x QSC PLD4.3
Klarity Audio & Lighting
https://www.facebook.com/KlarityAudio/
Re: Running tubas
#2 Post by Tom Smit » Sun Nov 25, 2018 11:50 pm
No, do not increase voltage.
FYI, when another cab is plugged into the first one, the impedance goes down...and that results in increase in current flow....which means more watts from the amp.
Re: Running tubas
#3 Post by Grant Bunter » Mon Nov 26, 2018 1:55 am
Why a new thread?
So many of your threads are asking the same question, or a variant of that question, time and time again. With or without new/different amplifiers.
Since it means you're essentially asking the same question, over and over, you're not making any effort at all to understand, and, given the amount of cabs you're running at times, you DO need to understand.
Check this older thread of yours, I'm pretty sure it's all explained there:
viewtopic.php?f=1&t=24966
The above thread tells you:
The impedance load the amplifier "sees" with pairs of cabs, both lab12 and lab12C loaded cabs, and the voltage limits those cabs require...
DR 250: x 2 (melded array) with March 2012 plans. 2 more under way with CD horn
T39's: 4 x 20" BP102 , 2 x 28" 3012lf.
WH8: x 3 with melded array.
Re: Running tubas
#4 Post by Grant Bunter » Mon Nov 26, 2018 2:41 am
No, it isn't what it is, and it shouldn't be either.
You have, IIRC, 2 pairs of dual loaded lab12's, and the rest are dual lab12C loaded?
And a venue 360.
So you should be always able to pair the lab12's together, and the lab12c's together on a different output of the 360 and amplifier channels, and limit them all to their appropriate voltage limit...
