titian vs sb850
nick mineau
titian vs sb850
#1 Post by nick mineau » Fri Oct 19, 2018 11:54 am
I am wondering if the chart used on the sb850 vs titian48 was at 2.83v or 2.0v for the eaw sb850.
the site clearly states that the titian was at 2.83v, but im not sure about the 850.
I assume it was done at 2v being a 4 ohm combined load for the 2 x 18s
:feedback:
Re: titian vs sb850
#2 Post by Bill Fitzmaurice » Fri Oct 19, 2018 12:44 pm
Unless otherwise noted all charts are 2.83v. That's what matters when you're trying to compare how loud two speakers are with the same amp and same settings. BTW, Titian was an Italian painter, not a subwoofer. :lol:
SethRocksYou
Re: titian vs sb850
#3 Post by SethRocksYou » Fri Oct 19, 2018 2:49 pm
I am wondering if the chart used on the sb850 vs titian48 was at 2.83v or 2.0v for the eaw sb850....
That chart depicts the Titan at 0.8 watts and the SB850 at 2 watts... 2.83v for both
Re: titian vs sb850
#4 Post by CoronaOperator » Fri Oct 19, 2018 2:57 pm
Amps put out voltage, not watts. Watts are a function of the voltage pushing current through an impedance. Ever seen an impedance chart of a cabinet? The impedance changes at every frequency, which means every frequency would have a different wattage at 2.83v. Might be 1w at 50hz, 0.7w at 55hz, 0.05w at 60hz, all depending on the impedance curve. That's why the charts use voltage, you can't keep the wattage equal across the frequency band unless your cabinet has a ruler flat impedance curve. Only thing that I know of that does is a ribbon tweeter.
SethRocksYou
Re: titian vs sb850
#5 Post by SethRocksYou » Fri Oct 19, 2018 3:24 pm
All true. However, just as one can average spl over a useful frequiency range, ohms can averaged too and used to calculate average watts. Which, personally I find useful. Just another tool, not a benchmark.
nick mineau
Re: titian vs sb850
#6 Post by nick mineau » Thu Oct 25, 2018 9:24 am
ok thanks! sorry about the typos.
and to be fair the titian is only receiving less then half the power, so it shows how much more efficient that design is.
the reason I was wondering, is some people rate a 4 ohm cab at 2 volts. some at 2.83 :wall:
BrentEvans
Re: titian vs sb850
#7 Post by BrentEvans » Thu Oct 25, 2018 11:46 am
:wall:
Re: titian vs sb850
#8 Post by Bill Fitzmaurice » Thu Oct 25, 2018 12:11 pm
Titian:
Signalsdrone
Re: titian vs sb850
#9 Post by Signalsdrone » Thu Oct 25, 2018 5:06 pm
ROFL!
nick mineau
Re: titian vs sb850
#10 Post by nick mineau » Tue Oct 30, 2018 7:07 am
lol :horse: good thing I didn't call it a Triton sub lol
BrentEvans
Re: titian vs sb850
#11 Post by BrentEvans » Tue Oct 30, 2018 6:44 pm
Yeah. At least Titians would have balls.
This post brought to you buy the department of Entendre Entendre.
