Narrow Titan 39 question
Double0
#1 Post by Double0 » Sat Jun 16, 2018 7:03 pm
Does no panel 7 mean that the speaker is left exposed.
Re: Narrow Titan 39 question
#2 Post by Bill Fitzmaurice » Sat Jun 16, 2018 8:03 pm
Only if you don't install the access panel.
#3 Post by Grant Bunter » Sun Jun 17, 2018 3:58 am
Never!
In the slimmest of cabs, you add the access panel flanges and mount the access panel.
Bill, that made me laugh...
DR 250: x 2 (melded array) with March 2012 plans. 2 more under way with CD horn
WH8: x 3 with melded array.
Double0
#4 Post by Double0 » Mon Jun 18, 2018 8:00 am
Ok guys another question am I doing it right I cut the hole for the speaker in panel 2 the and inserted the 3012lf and marked the holes.
By my understanding the 12 inch driver anchor is to go on the inside as a reinforcement? Also do I stick that in place with the PL as well?
#5 Post by Tom Smit » Mon Jun 18, 2018 8:20 am
Yes, as in what is written on page 8.
When you trace the outline of the anchor, put a couple of indicator marks on both the anchor and the baffle at the same spot. This will help in making sure that the anchor is installed in the exact location as when one was dry-fitting the parts.
Double0
#6 Post by Double0 » Tue Jun 19, 2018 4:32 pm
Sorry to be a pain guys just read the plans again and was wondering if the speaker is supposed to be flush with the baffle panel? I don't have the partial assembly here its at a friends workshop.
#7 Post by Bill Fitzmaurice » Tue Jun 19, 2018 4:56 pm
Have you looked at the sketchup model? If there's any way to make it more clear how everything goes together I'm open to suggestions.
Double0
#8 Post by Double0 » Tue Jun 19, 2018 5:12 pm
Reading it back i was wondering if I did mine wrong if you lay the baffle board down and then put the speaker through the hole I am wrong. I cut a hole so that the lip cannot get through, if you get me?
#9 Post by Grant Bunter » Wed Jun 20, 2018 3:22 am
That's not right. The baffle should have a hole large enough for the driver to fit inside.
The anchor needs a hole cut to not allow the lip to slip through...
Double0
#10 Post by Double0 » Wed Jun 20, 2018 9:15 am
Great so the speaker is flush fitting to the baffle panel in that the rim of the speaker is the same level as the baffle surface _____ _ _ _ ______ and not ___--------_____
\ ___/ \____/
SethRocksYou
#11 Post by SethRocksYou » Wed Jun 20, 2018 11:07 am
Looking at the sketchup, it's pretty clear the speaker is recessed into the baffle. The hole in the baffle would have to be large enough to put the whole speaker through.
Maybe turn your baffle into the anchor. Or, cut the hole bigger.
#12 Post by Bill Fitzmaurice » Wed Jun 20, 2018 11:59 am
Or read the plans. Page 7: Cut in the baffle a hole(s) slightly larger than the driver frame, so the driver can barely slip through it.
Double0
#13 Post by Double0 » Wed Jun 20, 2018 12:34 pm
Thanks Recessed is a great word for it!
Bill why is it recessed, just for informational purposes? Does it improve performance by having a greater distance between the access panel & speaker?
#14 Post by Bill Fitzmaurice » Wed Jun 20, 2018 12:41 pm
It improves performance and allows maximum depth of the access cover braces, for maximum access cover stiffness.
