Maximizing pack space and performance, under budget.
Re: Maximizing pack space and performance, under budget.
#16 Post by Bruce Weldy » Wed Jun 13, 2018 6:16 pm
J_Dunavin wrote:
Wed Jun 13, 2018 4:35 pm
Most of the time I run the full rig, but there are also many times that I only take the car. I made a cardboard mock up and at 20 inches I can still fit one in the back of the Buick with two DRs in the trunck.
I guess I could make just one slim one and not a pair?
If you build one slim - build two. That way any stacking will always be equal. Of course, that may be less of an issue with the T45
6 - T39 4-25" 2-22" 3012LF
4 - OT12 2512 Melded/NSD2005
J_Dunavin
#17 Post by J_Dunavin » Wed Jun 13, 2018 8:47 pm
Grant
It is a good idea, a single T39 with a pair of My DR 200s would work well, but I can't personally justify multiple designs at this point.
Two of my bp102 T24s did ok with a pair of DR200s, so I assume a lab or 3012 T45 will be ok as well.
Those smaller gigs I do are for like 50 kids or less, or background music for events.
6 - DR200
J_Dunavin
#18 Post by J_Dunavin » Wed Jun 13, 2018 8:49 pm
Oh one more.... The plans say a max width of 24? I thought the T30 could be made wider than that... Difference of the two designs?
6 - DR200
SethRocksYou
#19 Post by SethRocksYou » Wed Jun 13, 2018 10:34 pm
Thought I'd seen that too. Here's a chart from the "SPL Charts" section, indicating a 30" wide option.
27" wide seems to be fairly frequently used in the charts too.
#20 Post by Grant Bunter » Thu Jun 14, 2018 12:24 am
The T45 is a refolded T30, to make it end firing.
If the plans say max width for the T45 is 24", then that's the max width...
DR 250: x 2 (melded array) with March 2012 plans. 2 more under way with CD horn
WH8: x 3 with melded array.
