Can you mix speakers in a T39
Double0
#1 Post by Double0 » Mon May 28, 2018 9:20 am
Hi Guys,
Can you mix speakers and width sizes in the same design or is this no desirable.
Example a 20" wide with a lab 12 and a 16" wide with a 10" 3012LF.
Re: Can you mix speakers in a T39
#2 Post by Grant Bunter » Mon May 28, 2018 3:28 pm
Can you? Yes.
But you haven't built yet right?
Buy all the same drivers...
DR 250: x 2 (melded array) with March 2012 plans. 2 more under way with CD horn
WH8: x 3 with melded array.
Double0
#3 Post by Double0 » Mon May 28, 2018 3:40 pm
Thanks grant had found a special on some lab12's, was wondering if it made sense.
How do you use your t39 -bp102 vs using your t39-3012lf?
#4 Post by Grant Bunter » Mon May 28, 2018 4:11 pm
As I said earlier, it makes more sense to try and use the same drivers. Doing that from the outset is a good move.
The reason: They're recommended drivers, but they have slightly different responses, so need different EQ.
I use the 4 x BP loaded cabs on one sub output of my DCX2496 to limit and EQ them properly via one amplifier, then another output on the same device for another amplifier for the 2 x 3012lf loaded cabs.
I built the 4 x BP loaded cabs years ago. 20" wide is the maximum width for those cabs.
I built the 3012lf loaded cabs more recently, (because I got them cheap) as per the plans they are built to 28" wide, maximum width.
I've never been in a situation where I wish I had built slimmer cabs. A number of people will suggest building a pair of slimmer subs for smaller gigs. I just turn down. So build as wide as your pack space allows to maximise output. You can always turn down :)
Double0
#5 Post by Double0 » Mon May 28, 2018 4:53 pm
Waiting for a leg injury to clear up, then i will start my build, wanted to build a small set up to be honest as I had said before trying to keep thebpack size small and weight minimal as I make over my set and bring it into 2020. Can your pair of 3012lf keep up with your dr250?
#6 Post by Grant Bunter » Tue May 29, 2018 3:36 pm
If you want to keep weight down, only use the 3012lf in your subs. They save you about 14 pounds per cab compared to a lab12.
I've reckon the 4 x BP loaded cabs are about 3dB down compared to the DR250's, but the 2 x 28" 3012lf cabs seem to keep up...
Double0
#7 Post by Double0 » Wed May 30, 2018 5:08 am
Okay understood, I was wondering also if I changed the height to 37 from 39, if that would kill the design, that would allow me to go through the side doors and close easy.
#8 Post by Tom Smit » Wed May 30, 2018 7:58 am
The T39 is 39 inches tall, 19 1/2 inches deep, and whatever width you choose (from 13 inches to ....). It will fit through doorways with no problem because of the depth.
Double0
#9 Post by Double0 » Wed May 30, 2018 8:27 am
Between the 2 doors at the back is 38", it will butt the handles cross ways at 39", was just asking if that could be a possibility, would save some space if it could.
\=======/ as opposed to /II II \
/ II II \
I made a cardboard mock up
#10 Post by Grant Bunter » Wed May 30, 2018 3:00 pm
Yes, it would kill the design to reduce the height from 39" down to 37".
Double0
#11 Post by Double0 » Wed May 30, 2018 3:08 pm
Cheers, cant wait to start the build!!
#12 Post by Chris_Allen » Wed May 30, 2018 4:29 pm
Having built both T48s and T39s, the T39s are a joy to move around in comparison!
In both cases, wheels, wheels, wheels (and skid boards).
I don't treat my speakers with any kind of respect, the time I gain moving them is more time spent on the mix.
Double0
#13 Post by Double0 » Thu May 31, 2018 9:00 am
Chris, I know the feeling you use your T39's with your Dr200's? How wide are your T39's?
