T39 with a HO?
Double0
T39 with a HO?
#1 Post by Double0 » Sat May 26, 2018 5:39 am
Hey guys,
Can you use a Eminence Kappalite 3010 in a T39 Slim?
Re: T39 with a HO?
#2 Post by Bill Fitzmaurice » Sat May 26, 2018 8:10 am
Are the specs correct?
Double0
Re: T39 with a HO?
#3 Post by Double0 » Sat May 26, 2018 10:17 am
Re: T39 with a HO?
#4 Post by Bill Fitzmaurice » Sat May 26, 2018 10:27 am
That was a rhetorical question. I know the specs are not correct. You should too, as the correct specs are in the plans.
Re: T39 with a HO?
#5 Post by Bruce Weldy » Sat May 26, 2018 10:54 am
Not to mention.......but, I will. They no longer make that driver. Currently, there are no 10s in the Kappalite line.
6 - T39 4-25" 2-22" 3012LF
4 - OT12 2512 Melded/NSD2005
Double0
Re: T39 with a HO?
#6 Post by Double0 » Sat May 26, 2018 10:58 am
Sorry guys, but I did find some selling for memorial day.
Bill was there and SPL comparison with the T39 1 x 12 vs T39 1 x 10?
Re: T39 with a HO?
#7 Post by Bruce Weldy » Sat May 26, 2018 11:15 am
If you can find a KL3010LF - that will work, just not the HO. However, it really makes no sense to use a 10 when the 12 does so much more.
Re: T39 with a HO?
#8 Post by Bill Fitzmaurice » Sat May 26, 2018 11:33 am
That's not how you choose a driver. You either use one recommended in the plans or use one that has specs per the plans requirements. If you can find one that works and it's on sale that's nice, but price should not be the primary criteria, performance is. Buy once, cry once.
Double0
Re: T39 with a HO?
#9 Post by Double0 » Sat May 26, 2018 11:49 am
[/quote]
Okay thanks the hunt it is on.
