Tuba 30
Fellamelad100
Re: Tuba 30
#16 Post by Fellamelad100 » Fri Nov 10, 2017 9:43 pm
wow you guys know you're stuff . so tell me Chris how much you want for the cabs !
Fellamelad100
Re: Tuba 30
#17 Post by Fellamelad100 » Fri Nov 10, 2017 9:52 pm
Chris_Allen wrote:
DJPhatman wrote:Unless Chris_Allen still has a pair of DR200 for sale... :twisted:
Yeah, they are still sat on the shelf in the garage...
hello my friend , so how much would you take for these cabs ?
commander_dan
Re: Tuba 30
#18 Post by commander_dan » Fri Nov 10, 2017 10:00 pm
DJPhatman wrote: Do yourself a HUGE favor, and build yourself a pair of OTop 12s. Sell the JBLs, buy yourself a proper DSP and a lightweight 2 channel amp. Run your new T30s on 1 side, and your to-be-build OTop 12s on the other. You will not believe your ears on how much better your entire sound will be. Unless Chris_Allen still has a pair of DR200 for sale... :twisted:
OT12s are great, but they go very loud and will far outrun your pair of T30s. I'd say if you intend on extending your T30 collection to four, then yes build the OT12s. Otherwise they will be sitting below 1/2 volume most of their lives.. might be better to consider a smaller top, like a SLA pro or something. Just a thought.
6 T30 (24", 3012LF)
2 OT12 (MA, 3012HO)
2 T24 (18", 3010LF)
Running:
DCX2496
XTi 2002
XTi 4002
TRAKTOR Z2
TECHNICS 1210 Mk5's
Padde298
Re: Tuba 30
#19 Post by Padde298 » Wed Nov 22, 2017 9:24 am
DJPhatman wrote:
Fellamelad100 wrote:for what i do which would be a maximum of 300 these Tuba 30's and a pair of JBL 515xt's on top
This tells me you have not read the subwoofer placement sticky.
It also tells me you really aren't sure how to properly run your sound PA. The 515XT has got to be one of the worst-sounding boxes Harmon-Kardon has ever released to the public. Do yourself a HUGE favor, and build yourself a pair of OTop 12s. Sell the JBLs, buy yourself a proper DSP and a lightweight 2 channel amp. Run your new T30s on 1 side, and your to-be-build OTop 12s on the other. You will not believe your ears on how much better your entire sound will be. Unless Chris_Allen still has a pair of DR200 for sale... :twisted:
+1
Having bought this little set for app. 400,- EUR (used), I'm pretty shure not to run out of power in the near future... 4 x 1600+ watt in 4 ohm lets you play around with cabs with 8 and 4 ohm drivers, before you have to invest in another amp!
Furthermore you HAVE to read and UNDERSTAND the "Subwoofer Placement" sticky! It just makes all the difference how you line up your bass horns!
TSA 4-1300.jpg (15.27 KiB) Viewed 1406 times
2 x TAT
chrisj360
Re: Tuba 30
#20 Post by chrisj360 » Wed Nov 22, 2017 12:03 pm
I like what you did with the mouth braces. Did you improvise them or were they included in the older plans?
Side note, what glue are you using? PL premium doesn't match the color in the photo, but I know it could be different if outside the US.
2 x 21" T30's with Lab12's
2 x 28" T30's with Lab12's
Re: Tuba 30
#21 Post by Grant Bunter » Wed Nov 22, 2017 3:48 pm
Padde298 wrote: +1
Padde (and anyone else this may apply to),
Please be aware, for Bill's designs, well, really, for any design where you could set a voltage limit, there is such a thing as to much power!
Based on the specs quoted, 1220W/8 ohms = 98V, and 1600W/4ohms = 80V.
Let's say an 8 ohm driver has a limit of 50V.
With one cab, on one channel of your amp, that means you need to limit by 48V!
While that may be achievable with your DCX (I"m not sure you can limit that much), it will most likely mean you are constantly engaging the limiter just to run your cab, and that's bad.
2 x 50V limited 8 ohm drivers in parallel is 4 ohms, and with a 80V output at 4 ohms, you have reduced the amount of limiting to 30V. That might be more within the capabilities of the DCX, and mean you are not constantly hitting the limiter.
What are your current settings and have you ever seen the limiter light engaged?
WH8: x 3 with melded array.
Svartrose
Re: Tuba 30
#22 Post by Svartrose » Thu Nov 23, 2017 3:22 am
Why shouldn"t you just pit one of the gains right and use a limiter? (A gain without a knob ofcourse)
Re: Tuba 30
#23 Post by Grant Bunter » Thu Nov 23, 2017 4:38 am
Svartrose wrote:Why shouldn"t you just pit one of the gains right and use a limiter? (A gain without a knob ofcourse)
A number of us, but not everyone, advocates settings attenuators to max when setting limiters.
That way, there is never a "surprise" when the fella trying to be helpful turns to you and says "i've fixed the volume for you", and suddenly... silence.
Even without a knob, the post in the middle of the pot can be turned.
It's simply amazing just how many people in the world know how to run pro PA properly :? :shock:
You can do it as you suggest, but I would put the pots in the case if I did that.
Or buy the right power amp in the first place.
Something to be aware of...
Padde298
Re: Tuba 30
#24 Post by Padde298 » Thu Nov 23, 2017 5:13 am
Grant Bunter wrote: What are your current settings and have you ever seen the limiter light engaged?
I do indeed have this specific problem in my set up. I therefore never turn the attenutators of the amp up full. The DCX can't handle a limitation in that range. I am driving TAT with the TSA 4x1300, which is TOTALLY overkill! :horse:
But to answer your question; I always have the limiter enganged on the sub out! The small 8" would probably not last too long if I didn't. Having calculated the voltage limit of the drivers, and have set the limiter accordingly (with the amp only turned up halfway. It leaves the door open for someone to turn them up further, which could kill the drivers. But the TSA 4x1300 was bought before the build of the TAT (love them <3), and they are actually built for a totally different set-up..: my sound bike. Let's hope they live that long... :loler: :loler: :loler:
2 x TAT
Fellamelad100
Re: Tuba 30
#25 Post by Fellamelad100 » Tue Nov 28, 2017 1:21 pm
chrisj360 wrote:I like what you did with the mouth braces. Did you improvise them or were they included in the older plans?
Fellamelad100
Re: Tuba 30
#26 Post by Fellamelad100 » Tue Nov 28, 2017 1:24 pm
Hi Chris I designed the braces myself , just didn't like the original one , thought it needed spicing up a little , just used PU glue nothing special .
Fellamelad100
Re: Tuba 30
#27 Post by Fellamelad100 » Tue Jan 09, 2018 6:48 am
:feedback:
One coat of Tuff cab paint just need another couple of coats.
Padde298
Re: Tuba 30
#28 Post by Padde298 » Tue Jan 09, 2018 8:37 am
WAUW!!!! :hyper: :hyper: :hyper: :hyper: :hyper: :hyper: :hyper: :hyper: :hyper: :hyper:
2 x TAT
Re: Tuba 30
#29 Post by Chris_Allen » Tue Jan 09, 2018 11:29 am
Nice! Any reason why one has a speaker mount and the other doesn't?
Re: Tuba 30
#30 Post by Bill Fitzmaurice » Tue Jan 09, 2018 11:43 am
Perhaps he knows that if he does have occasion to put a top above one sub the second sub should be clustered next to it.
