Any tuba 60s for sale?
DJStubbs
#1 Post by DJStubbs » Fri May 12, 2017 7:30 pm
Im looking for 2-4 t60s dual lab12 30x30x60.
If anyone has any sitting around they dont need let me know!
Im not picky on how used they are or if someone is interested in making me some.
18x Tuba 60 - Dual 12" LAB
6x Renkus Heinz ST6
1x Lab Gruppen PLM10000Q
2x QSC PLD4.5
2x QSC PLD4.3
Klarity Audio & Lighting
https://www.facebook.com/KlarityAudio/
jose99a
Re: Any tuba 60s for sale?
#2 Post by jose99a » Fri May 12, 2017 9:08 pm
Didn't you post some for sale with the same specs...?
Are you pulling our leg?
#3 Post by CoronaOperator » Sat May 13, 2017 7:56 am
jose99a wrote:Didn't you post some for sale with the same specs...?
"If you can't beat em, join em!"
DJStubbs
#4 Post by DJStubbs » Sun May 14, 2017 5:57 pm
If I don't sell mine I'm going to buy more. My setup right now is not loud enough so I either need more or something different.
6x Renkus Heinz ST6
2x QSC PLD4.5
2x QSC PLD4.3
Disco-inferno
#5 Post by Disco-inferno » Mon May 15, 2017 2:06 pm
Just make sure you get the setup you have working first! T60's not having output beyond 10ft. will not necessarily become better when you combine them with more cabs. More of the same problem is still the same problem!
DJStubbs
#6 Post by DJStubbs » Tue May 16, 2017 6:28 pm
Disco-inferno wrote:Just make sure you get the setup you have working first! T60's not having output beyond 10ft. will not necessarily become better when you combine them with more cabs. More of the same problem is still the same problem!
Will they ever have a performance past 10ft? What am i doing wrong then? I feel its all being done right.
6x Renkus Heinz ST6
2x QSC PLD4.5
2x QSC PLD4.3
#7 Post by Bruce Weldy » Tue May 16, 2017 11:04 pm
Until you take the covers off and check the speaker wiring inside the cabs, you are just spinning your wheels trying everything else.
Like when you call computer support - the first thing they ask is if it's plugged in. This is the equivalent. You gotta' start at the beginning, or you'll never know. You didn't build 'em, so you just can't be sure of the situation.
6 - T39 4-25" 2-22" 3012LF
4 - OT12 2512 Melded/NSD2005
#8 Post by Tom Smit » Wed May 17, 2017 12:02 am
+1
#9 Post by Bill Fitzmaurice » Wed May 17, 2017 7:33 am
DJStubbs wrote: I feel its all being done right.
If it was you wouldn't be having these problems. We've told you what you need to do. We can't do it for you.
Monomer
#10 Post by Monomer » Fri May 19, 2017 12:59 am
DJStubbs wrote: Will they ever have a performance past 10ft? What am i doing wrong then? I feel its all being done right.
I'm using my two t39's to fill a warehouse this weekend. It's not crazy amount of bass, but I've gotten complements. Sounds nice outside, too.
You've got issues if six t60's have no output. Are the dual-driver? - are the drivers wired with reverse polarity? Have you checked for leaks? You should be peeling paint off walls with them!
-More to come!
DJStubbs
#11 Post by DJStubbs » Fri Jun 01, 2018 4:35 am
Bump. Still looking for some if anyone has any. Dual lab12. I have figured it all out and got them working properly. I still need moar bass though. 10 is not enough for me. I feel that can handle maybe 2k people outside. I need more.
6x Renkus Heinz ST6
2x QSC PLD4.5
2x QSC PLD4.3
Rich4349
#12 Post by Rich4349 » Fri Jun 01, 2018 12:26 pm
Did you have some of them wired out of polarity, either within each cabinet, or from cabinet to cabinet?
