New Amps
DJStubbs
New Amps
#1 Post by DJStubbs » Mon Feb 13, 2017 9:39 pm
I may be buying 4 more Tuba60 Dual LAB12 Subs soon
and right now i am running 2 EP4000s for my current 4 t60s
What amps should i get to run all 8. would 2 crest 5.0s be powerful enough or maybe 2 3.0s?
Or should i go bigger? I want to try and keep it around 2 amps but 4 could be ok if they arent too expensive.
Trying to keep it under $2000
And i do use generators sometimes.
I would keep getting ep4000s but i had issues with my 2 and they are also very heavy.
And what do you guys recommend i do for inputs to outputs for all these amps. A normal mixer from a DJ only has 2 xlr outputs.
I dont think y splitter XLRs would be the best idea. But i dont know.
If i went crest i could get 2 XLR outputs and an inputs.
I dont have a problem buying another drive rack pa2.
10x Tuba 60 - Dual 12" LAB
5x DR280 - Melded 22 piezo array
2x Crest Audio 5.0
1x Peavey IPR2 3000
https://ibb.co/e0Uazv
https://ibb.co/bUxmJQ
Klarity Audio & Lighting
https://www.facebook.com/KlarityAudio/
Re: New Amps
#2 Post by Bruce Weldy » Mon Feb 13, 2017 11:52 pm
DJStubbs wrote: I dont think y splitter XLRs would be the best idea. But i dont know.
Absolutely nothing wrong with a Y to the amps.....that's no different than using an in and an out....it's just a parallel pass through.
If there isn't a parallel input on the amp (it could be XLR or TRS), make the jumper at the amps. This is the only pic I have of this connection....from a rack a did a few years back. Kinda' grainy, but you can see the jumper from the bottom amp to the one above it.
6 - T39 4-25" 2-22" 3012LF
4 - OT12 2512 Melded/NSD2005
DJStubbs
Re: New Amps
#3 Post by DJStubbs » Mon Mar 27, 2017 2:49 pm
If I wire my t60s in series what are the ohms they produce?
2x Crest Audio 5.0
1x Peavey IPR2 3000
Re: New Amps
#4 Post by Grant Bunter » Mon Mar 27, 2017 4:06 pm
DJStubbs wrote:If I wire my t60s in series what are the ohms they produce?
Dual lab12 loaded cabs in series, so add nominal impedance. 6 + 6 = 12ohms per cab
You can also add +2 ohms per cab above that for acoustic impedance, but when it comes to amps and what to use, personally I think one is better off ignoring that.
Not sure why you didn't add to the amps post you had a short while back.
Can I just say you need to start learning all this stuff. Not just let us answer for you.
Why?
Because your reputation as a DJ depends not only on your ability to DJ, but also on your equipment working without fail, and, you need to know all this stuff so that at any gig, if something does fail, you can fix the problem on the fly and keep the show going.
Not said at all as a criticism, just trying to help you and your business...
WH8: x 3 with melded array.
DJStubbs
Re: New Amps
#5 Post by DJStubbs » Mon Mar 27, 2017 4:59 pm
Why?
I was asking good questions. People have their own setups and im curious what they use??
And i heard differently and I was double checking. and i dont dj anymore i rent this stuff out to djs and festivals/events.
I realize that you add 2 for the box. i plan on running 2 per channel on my amps. just wondering if i could do 3 per channel.
I am here to learn that is why i am here. I think this is better than me going off and having shit happen at a gig.
I can prevent things from happening before it even does.
2x Crest Audio 5.0
1x Peavey IPR2 3000
Re: New Amps
#6 Post by Bruce Weldy » Mon Mar 27, 2017 5:11 pm
DJStubbs wrote: i plan on running 2 per channel on my amps. just wondering if i could do 3 per channel.
Grant is correct that you need to learn the math on this stuff, but that aside - without knowing exactly which drivers (I assume Lab12s from the earlier post) and which amp (you mentioned maybe getting something else if I remember correctly), it's hard to properly answer the question.
When asking that kind of question, it's in your best interest to lay out exactly what the gear is so there is no ambiguity......that could get you a wrong answer that could cost you money.....plus, it keeps those of us who are willing to help you research and provide an answer from having to read though a bunch of old posts to figure out just where you are going.
So, give us the particulars and we'll help ya' out.
DJStubbs
Re: New Amps
#7 Post by DJStubbs » Mon Mar 27, 2017 5:18 pm
I have 2 crest audio 5.0 amps for my 6 t60s dual lab 12.
Now ive been told that i would have to wire series due to the larger voltage output.
So i am going to be doing that very soon.
I do plan on getting 2 more t60s in the next 6 months. if not sooner.
I plan on having around 10-12 in my final setup.
2x Crest Audio 5.0
1x Peavey IPR2 3000
Re: New Amps
#8 Post by Bill Fitzmaurice » Mon Mar 27, 2017 5:22 pm
DJStubbs wrote: i dont dj anymore i rent this stuff out to djs and festivals/events.
Never rent anything that you won't mind getting back broken. The only way to be sure your gear doesn't get destroyed is to rent out your services along with the gear, and never let anyone else mess with the system.
DJStubbs
Re: New Amps
#9 Post by DJStubbs » Mon Mar 27, 2017 5:26 pm
I have a smaller PA for djs to rent. but a few do rent my bigger pieces.
And im normally always there to watch it. or i set up and leave and come back.
2x Crest Audio 5.0
1x Peavey IPR2 3000
Re: New Amps
#10 Post by Bill Fitzmaurice » Mon Mar 27, 2017 5:35 pm
DJStubbs wrote:i set up and leave and come back.
There's a thread posted here recently where someone did just that, and got a blown OTop 12 as a result when some moron managed to plug in a keyed Speakon the wrong way, by destroying the Speakon. Don't think that you can win the battle against idiots. You're vastly outnumbered.
Re: New Amps
#11 Post by Grant Bunter » Wed Mar 29, 2017 4:33 pm
DJStubbs wrote:I have 2 crest audio 5.0 amps for my 6 t60s dual lab 12.
It's not just because of larger voltage output of the amplifier, it's also about trying to manipulate impedance loads to maximise cabs per channel, and reduce amplifier strain.
It was also said to wire the cabs internally with serial drivers, and connect those cabs in parallel.
The Crest 5 amplifier specs say, using 20Hz-20Khz output figures, that with 2 ohm per channel loads, that output is a max of 2250W, or 67V.
Could you use three cabs per channel? Yes.
Should you use three cabs per channel? No.
Your new investment (eg the Crest 5.0 amps) will work for much longer and with less strain if you use a maximum of 2 cabs per channel. 3 cabs per channel is starting to flog the amp to death.
Initially, in the other thread I think, it was said the Crest 5.0 was capable of 105V. Turns out the spec sheet says maximum voltage swing is 105V. Please note though that's different from what the output figures say...
DJStubbs
Re: New Amps
#12 Post by DJStubbs » Thu Mar 30, 2017 2:07 am
Ok thank you!
2x Crest Audio 5.0
1x Peavey IPR2 3000
