It is currently Sat Jun 24, 2017 8:45 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page 1 2 Next
Author Message
PostPosted: Fri Apr 01, 2011 12:13 am
Offline
http://www.minidsp.com/onlinestore?page=shop.product_details&flypage=flypage.tpl&product_id=72&category_id=17
PWR-DSP3
Price per Unit (piece): US$1 299.0
Quantity Price
0 - 1 US$1 299.0
2 - 10 US$1 199.0
Number pieces in packaging:1
Number pieces in box:1
The PWR-DSP3 answers the needs for a high power yet high quality plate amplifier module. Based on the innovative technology from DSP4YOU and PASCAL Audio, the module is a turnkey solution for multi-way powered speakers. Third generation Class-D amplification, Digital Signal Processing (DSP) and the Audio Video Bridging (AVB) are just examples of the embedded technology of this breakthrough plate amplifier module.
With an impressive maximum rating of 2400W (ch1) and 700W (ch2&3), expect no compromises on audio quality from this first class plate amplifier. From studio/Hifi speakers to Pro-A/V applications, its passive cooling design does not require any fan. Enjoy silence, Enjoy music.
Last but not least, the optional Audio Video Bridging (AVB) allows streaming of multiple uncompressed, low latency and synchronized audio channels of over Ethernet networks. Extended cable length, noise immunity and flexible routing are the obvious advantages of AVB. From real time amplifier health monitoring (Load, temperature, clip) to live changes of the DSP settings, the PWR-DSP3 is powered by Zeroconf for true Plug & Play configuration over standard Ethernet or Wifi networks: Plug, discover, control!
For more detailed information, please consult the PWR-DSP3 product datasheet.
OPTIONS
* Audio Video Bridging (AVB) option
BOX CONTENT
* 1 x PWR-DSP3 amplifier module
* 1 x Startup guide
* 1 x PowerCON AC power cable
Product Availability: End of April 2011.
IMPORTANT NOTE: This product is available on our webstore for pre-order only since it is currently not in stock. To pre-order a PWR-DSP3 module, add to cart and process a complete order all the way to the submit button. Simply do not pay your order through the paypal gateway and our sales team will contact you once your order is ready for shipping. Don't hesitate to contact our team for more information.
Top
PostPosted: Fri Apr 01, 2011 8:33 am
Offline
Posted within 20mins of each other how is that for random.
viewtopic.php?p=152162#p152162
They look damn interesting for small pro setups. That is a lot of power kicking round there.
Top
PostPosted: Fri Apr 01, 2011 9:02 am
Offline
As was mentioned before, these look really similar to the Digmoda amps Leland carries. The ethernet business sounds interesting, but I would want to see some detailed specs. Is the wattage rating "Peak" meaning 1200 and 350 RMS?
Pretty cool either way. If I had had more vision when I began I would have invested in some Digmoda amps.
Benj
_________________
http://www.fofg.org
Peavey and Madisound Dealer
Top
PostPosted: Fri Apr 01, 2011 9:27 am
Offline
Power ratings (RMS @ 1% THD)
Channel 1: 800W @16, 1550W @8, 2400W @4, 4000W Peak
Channel 2: 200W @16, 400W @ 8, 700W @4, 1400W Peak
Channel 3: 200W @16, 400W @ 8, 700W @4, 1400W Peak
_________________
Greg Plouvier
Top
PostPosted: Fri Apr 01, 2011 12:06 pm
Offline
Bigger power than digmoda. Same ball park on price. Any info on the dsp package?
_________________
Top
PostPosted: Fri Apr 01, 2011 3:36 pm
Offline
From what little I know about amp specs I think a Damping factor> 1000 @ 8ohms is weak for the price. I realize the DSP is the $$$ factor but it is still an amp. Most guys run a 4ohm load which raises the factor and so does cable size and length. I'm not sure how much that would affect the audio signal but why push it.
These are definitely purposed for powered cabinets @ 8 ohms.
Correct me i'm wrong.
_________________
4 20" T39(built)
2 WH8(built)
3 WH10(own)
4 DR200(own)
1 Jack 12(built)
SAC 24 Channel Mixer
SAW STUDIO Recording
Top
PostPosted: Sat Apr 02, 2011 11:01 am
Offline
Damping factor is irrelevant
_________________
Greg Plouvier
Top
PostPosted: Sat Apr 02, 2011 11:59 am
Offline
It appears that none of the plugs have limiters. If they would add that to the software it would be a pretty nice little DSP for under $200.
_________________
Greg Plouvier
Top
PostPosted: Sat Apr 02, 2011 12:12 pm
Offline
Damping factor is moot.
http://www.diyspeakers.net/Articles/Ric ... FACTOR.pdf
Top
PostPosted: Sat Apr 02, 2011 3:58 pm
Offline
Thank you. That dispels a lot of myth in these parts.
_________________
4 20" T39(built)
2 WH8(built)
3 WH10(own)
4 DR200(own)
1 Jack 12(built)
Top
PostPosted: Sat Apr 02, 2011 4:09 pm
Offline
Not in these here parts. Must be you're spending too much time in some other parts! :mrgreen:
Top
PostPosted: Sun Apr 03, 2011 5:30 pm
Offline
I would plan on it having limiters. This company seems bent pleasing it's customers, which is very rare nowadays. If enough people request an added feature they usually include it in form of a free downloadable update.
I read that it can be controlled via wifi or cable, but I'm not sure if it would stream music over wifi as well. I really would not mind spending the $700 for two with all the bells and whissles, but just one may be overkill for even four drs and four tubas.
Top
PostPosted: Sun Apr 03, 2011 5:40 pm
Offline
???! I think you might have missed the "1" before the 299 ;)
_________________
Top
PostPosted: Sun Apr 03, 2011 6:17 pm
Offline
It's $300 for one, $400 for two, $150 extra each for the connectivity feature.
Top
PostPosted: Sun Apr 03, 2011 6:25 pm
Offline
I think you might have missed the "1" before the 299, again.
_________________
Top
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
banner
Powered by phpBB® Forum Software © phpBB Limited
