Hey guys I have an old amp Yamaha M-85.
It has 3 pairs R/L channels. Does this have any potential in HT use? Or is it better suited for zone usage or garage duty?
Thanks
Yamaha M-85
Re: Yamaha M-85
Stereo doesn't cut it for HT.....so, it's off the to garage or some other area where you listen in stereo.
Re: Yamaha M-85
I'd use it with dual subs, or just one channelBruce Weldy wrote:Stereo doesn't cut it for HT...
if I only had one sub, bird in the hand that it is.
Re: Yamaha M-85
Bill Fitzmaurice wrote:I'd use it with dual subs, or just one channelBruce Weldy wrote:Stereo doesn't cut it for HT...
Great thanks Bill and Bruce.
One more question:
I also have a Denon POA-5200 amp.
If I were to build a LPTHT with the Dayton Audio DVC385-88 15" DVC Series Subwoofer which Amp would be the choice?
Thanks again,
Oscar
Re: Yamaha M-85
Look at the ampere current draw on the back panels. Whichever is the higher probably has the most rubust power supply. The Denon says 4.7 amp on the spec sheet.
