wireless signal
wireless signal
How well do you think these would work in a PA system?
https://www.parts-express.com/pedocs/ma ... manual.pdf
Would there be any benefit? Do any bands use this to avoid using a stage snake?
Re: wireless signal
I'd hate to rely on mini connectors in a PA situation, but it's doable.
Are you thinking about using them for delay speakers? The spec sheet says 20 meters - "light of sight" - whatever the hell that means. Maybe it's supposed to be line of sight, which would make more sense. In that case, you have to make sure the signal can't get interrupted by trees, people, birthday clowns, bears....
While it may be viable in a home theater situation, I'd be very leery of running that when you have to be sure it's going to work.
Re: wireless signal
A $20 cable is a million times more reliable than a $15k wireless system.
Re: wireless signal
I didn't have a specific application in mind, just wondering. Gear head dreaming.
Re: wireless signal
And it may be ten million times better than a $58 wireless system.CoronaOperator wrote:A $20 cable is a million times more reliable than a $15k wireless system.
Re: wireless signal
Things like these work perfect in an empty room with nobody in them. Then 800 people show up 10 minutes before showtime and all 800 of their cell phones (which also operate at 2.4 Ghz) try and ping anything and everything wifi and the system fails just as the band walks on stage without any warning.Bruce Weldy wrote: I'd be very leery of running that when you have to be sure it's going to work.
Re: wireless signal
And that's one more reason why I HATE wireless mics and guitar rigs. Batteries die....static.....the very building you are in can have an effect on performance......hate 'em.CoronaOperator wrote:Things like these work perfect in an empty room with nobody in them. Then 800 people show up 10 minutes before showtime and all 800 of their cell phones (which also operate at 2.4 Ghz) try and ping anything and everything wifi and the system fails just as the band walks on stage without any warning.Bruce Weldy wrote: I'd be very leery of running that when you have to be sure it's going to work.
Re: wireless signal
Excellent point.CoronaOperator wrote: Things like these work perfect in an empty room with nobody in them. Then 800 people show up 10 minutes before showtime and all 800 of their cell phones (which also operate at 2.4 Ghz) try and ping anything and everything wifi and the system fails just as the band walks on stage without any warning.
Re: wireless signal
Rich4349 wrote:How well do you think these would work in a PA system?
Behringer seem to have got it right. Live with it. it's the future of mixing desks.
But switch off the other free WiFi in the venue.
Re: wireless signal
Mkulu wrote:Rich4349 wrote:How well do you think these would work in a PA system?
This has nothing to do with Behringer or Pro Audio in general. The big boys are running Cat5, not wireless from FOH.
Re: wireless signal
Only the control surface is wireless, all the audio still goes through wires and the desk still functions on auto-pilot if the signal is lost. The reliable sound operators still have a wired laptop to the box just in case, monitors and side fills in case the wireless IEM's go down, and a few wired mics off to the side in case the wireless mics go down and a few instrument cables ready to go in case the wireless on them goes down. Back up plans for their back up plans.Mkulu wrote: Behringer seem to have got it right. Live with it. it's the future of mixing desks.
While wireless is a godsend for convenience, that $20 cable still beats it.
