Problem with DEQ2496
I have 2 DEQ2496's currently running on 2 monitor mixes. After a couple of hours of rehearsal, one of them started restarting on its own, operating for a minute or so, and restarting again, constantly. Has anyone run into anything like this? Is it a heat issue? I wouldn't think so, considering both are in the same rack. Is it just a bad unit? I don't think it has happened before this past weekend.
BFM Builds:
2 x SLA Pro
2 x Jack 12
2x T24
4 x WH6
2 x SLA Pro
2 x Jack 12
2x T24
4 x WH6
Re: Problem with DEQ2496
Try a new IEC power cord. I've had intermittent power issues with mine and the power cord was the fault.
Or just make sure that it's plugged all the way in. Those can get loose in a rack also.CoronaOperator wrote:Try a new IEC power cord. I've had intermittent power issues with mine and the power cord was the fault.
With my issue it was plugged in, just bad contacts in the cord
Had a similar failure with an other device.
Could be a faulty capacitor.
If there is no Warranty on it, open it and check for "Blown up" Capacitors
Normally a cap should have a flat top, not a rounded "Blown up" one.
Seems like it was the power cord. I turned it back on with the same cord (after making sure it was attached properly) and with nothing else running in the rack, it started acting up again. I changed the cord out with the other DEQ in the rack and it hasn't had any problems yet.
BFM Builds:
2 x SLA Pro
2 x Jack 12
2x T24
4 x WH6
2 x SLA Pro
2 x Jack 12
2x T24
4 x WH6
I carry dozens of extra IEC cables with my rig.
There always seems to be a couple missing or a band member forgot one or one gets mangled.....
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
6 OT12
4 T48
4 WH8
Other:
Way too many cables
I have one and it had issues overheating in my amp rack, particularly on a hot day in the sunlight. It would lock up with a memory error requiring a reboot. I have since moved it into an effects rack at FOH and no issues since.
