Mackie DL1608 Owners
T_Gowan
#1 Post by T_Gowan »
Hi
Im still using older FW, 1st gen IPad.
In the eq section of outputs there is a hi and lo pass filter can be set for 24 db per octave, If I us Aux feed sub and 50hz hi and 100 low pass is this a acceptable substitute for xover.
Also the comp limiter set to max limit seems to clamp voltage at the level you set it at.
Does any of this make sense for a small pub, club PA
Any body fooled around with this before?
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
T_Gowan
Re: Mackie DL1608 Owners
#2 Post by T_Gowan »
Guess the Mackie wasn't a big seller :D
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
dswpro
#3 Post by dswpro »
I've only used the Mackie a couple times. The real big issue around using an output section of a digital mixer as a crossover is in the minimum attack time on the limiter. I would research that carefully on the Mackie. As many have stated here, the horn loaded subs sound great until they stop operating if you happen to overdrive them. Some here have used the X32 outputs for a crossover, but the X32 claims zero attack time compressors. In general I prefer to use a system controller like the driverack or Behringer DCX2496, since it takes the limiters and crossover settings out of the hands of a console operator.
sine143
#4 Post by sine143 »
as crossovers they are fine, particularly if you aux feed your subs.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
Curtybob
#5 Post by Curtybob »
sine143 wrote:as crossovers they are fine, particularly if you aux feed your subs.
+1
Dig the crossover and EQ's on the Mackie. The compressor as a limiter? I don't care for the compressor except for super-ultra-mega-light use. Using it as a limiter feels a bit slow.
T_Gowan
#6 Post by T_Gowan »
I did play around with the comp. 80hz tone, set it for various voltages to match my various sub. pushing the output on the aux so it was really hitting it constantly and the voltage crept up 10ths of a volt. I will play with it some more set at lower outputs and make sure it holds at the proper level.
Neat thing is you can save compressor presets for different sub/amp combinations.
I do have a DCX and DEQ but looking for other possible situations in case of equipment failure etc.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Curtybob
#7 Post by Curtybob »
It will limit a constant signal, but I'm thinking it is too slow to catch sharp peaks.
T_Gowan
#8 Post by T_Gowan »
Very true, fast transient signal would probably get through.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
