I decided to build a Simplexx 15sub the other day. I have a couple 3015lf drivers not being used right now, and I was curious how these sound. Between yesterday and today I have about 7 hours into it, and now it just needs covered and wired. I did this build with a circular saw, and a janky jigsaw I picked up from a pawn shop. And my pawn shop brad nailer, which made things so much easier.
Should have a sound test by next week, we'll see how work goes. I did take a few pictures, but they'll have to wait till I get home.
Overall, it was a very easy build, less than a single 4x8 sheet. It'll probably stay in my practice space, supporting an electronic drum kit. If I really like it, another will be built and it may get bumped to small PA duty..
Who else has done one of these??
My first Simplexx 15sub build.
Re: My first Simplexx 15sub build.
Pictures I took along the way. (not sure why my computer rotated them all funny?)
- Attachments
- Skipped a few photo opportunities.... box assembled.
- image5.JPG (24.72 KiB) Viewed 2855 times
- The 'not so pretty' inside shot.
- image4.JPG (30.9 KiB) Viewed 2855 times
- Ready for the fabric inside to hold the stuffing back.
- image3.JPG (30.09 KiB) Viewed 2855 times
- Mounting baffle.
- image2.JPG (28.33 KiB) Viewed 2855 times
- Sides and half the baffle done, working on the 2nd part.
- image1.JPG (28.61 KiB) Viewed 2855 times
- Chris_Allen
Looks good.
I can't remember seeing a build thread on one but I was planning to do exactly the same with a spare pair of 3015LFs.
I'm hoping it meshes well with a pair of 5.25' + 1' silk dome studio monitors. They sound really good, just don't have any real low end to speak of.
- Chris_Allen
You've built them with the pro sound 8" ducts? are you planning on using them for a HT application?
No, it'd be for my practice room. I'd like to be able to use it for the low range for my studio monitors too. In the practice space, it'd be used with a couple Coaxial 12" monitors (not a simplexx design).
I've been considering repurposing the coax 12s for the simplexx monitor. That or the WH8. I think I'd like the WH8 more though.
I did a quick test tonight. Ran mono into a PA2, into a Stewart World 1.2 power amp. CH1 highs, CH2 Sub. I used a 3015 loaded Jack15 w/ full melded with the Simplexx 15sub. While I had to hold back the Jack, the 15Sub still surprised me in terms of output. The bass was clean and punchy. I put a high pass of 43hz on it, and crossed the tops 48LR at about 93hz. The sound was very impressive. I'm almost sure I'll be building another in the near future.
- Chris_Allen
Very nice!
The WH8 is an incredible little monitor.
