Acrylic Horn?
Acrylic Horn?
Could you build a horn loaded subwoofer like the T60 out of acrylic? I've just had thoughts of lighting up one with led's and showing off the awesome design by making it see through. Possible issues are air tightness and throat pressure, the question is could it handle it and could it be built? I'll leave cost analysis to another day. Also, what kind of thickness would be strong enough? Assume that if a width less than 1/2 inch is used all the respective panel sizes are adjusted automatically.
2 x TLAH
1 Titan 39 (lab 12, 15 inch)
1 Tuba 60 (lab 12, 20 inch)
SLA Center
2 x Mini MLTP subwoofers
1 x 212 TH (custom)
2 x Mini-Karlsonators
Owned, but not built
2 x Jack 12 (2512, melded)
2 x TLAH
SLA Center
1 x 212 TH (custom)
Re: Acrylic Horn?
Yes.MissileCrisis wrote:Could you build a horn loaded subwoofer like the T60 out of acrylic?
1/2 inch, which goes for $300 per 4x8 sheet.Also, what kind of thickness would be strong enough?
Better wait until transparent aluminum becomes available.
Re: Acrylic Horn?
In my lifetime, I want to see a 1 piece 3d printed plastic BFM cab.Bill Fitzmaurice wrote:1/2 inch, which goes for $300 per 4x8 sheet.
Frédéric Gélinas, HF Audio
Authorized Builder
HFAudio.ca
Free tone Generator
Authorized Builder
HFAudio.ca
Free tone Generator
Re: Acrylic Horn?
It would be rough if you messed up a panel at that kind of price, but I'm sure there is someone who could afford it (hopefully me in 10 years). I too would like to see a 3D printed cab!
2 x TLAH
SLA Center
1 x 212 TH (custom)
2 x TLAH
SLA Center
1 x 212 TH (custom)
Re: Acrylic Horn?
Even if one side was done with Acrylic, it would look cool.
Re: Acrylic Horn?
go with lexan.
I've personally been thinking about doing ply cabs, but cnc routing out reliefs, and replacing with foam/fiberglass to bring weight down.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
Re: Acrylic Horn?
Lexan is 850 a sheet... Maybe in my dreams.sine143 wrote:go with lexan.
2 x TLAH
SLA Center
1 x 212 TH (custom)
2 x TLAH
SLA Center
1 x 212 TH (custom)
Re: Acrylic Horn?
300, 800, just numbers when you get that high. lol. Might as well mold it out of polyester resin.
you could also probably get by with thinner lexan for an autotuba. lol.
1x bastard XF208
1x bastard XF208
Re: Acrylic Horn?
I like how you think, may as well go all the way if you're going to spend that kind of money.
2 x TLAH
SLA Center
1 x 212 TH (custom)
2 x TLAH
SLA Center
1 x 212 TH (custom)
- Hackomatic
Re: Acrylic Horn?
Thread resurrection . .
Lexan? Absolutely!
$800 Nah . . .
http://freckleface.com/shopsite_sc/stor ... uct48.html
Lexan? Absolutely!
$800 Nah . . .
Dave H
Re: Acrylic Horn?
LOL.Bill Fitzmaurice wrote:Yes.MissileCrisis wrote:Could you build a horn loaded subwoofer like the T60 out of acrylic?1/2 inch, which goes for $300 per 4x8 sheet.Also, what kind of thickness would be strong enough?
Any whales gone missing lately?
Re: Acrylic Horn?
Lexan?
Stuff gets scuffed when you look at it the wrong way.
-More to come!
-More to come!
Re: Acrylic Horn?
Re: Acrylic Horn?
We don't use 3/4 inch.jimbo7 wrote:Found the next gen of cab material
