Heathkit AS-27
Got speaker theory questions? This is where you'll find the answers.
DJMB
Heathkit AS-27
#1 Post by DJMB »
I just picked up a pair of these speakers, which is actually a Jensen Sigma SG-300 rebadged, and would like to know if they can be used in any of the BFM speaker designs.
A WORD TO THE WISE ISN'T NECESSARY, IT'S THE STUPID THAT NEED HELP
Re: Heathkit AS-27
#2 Post by Grant Bunter »
It is usual to post TS parameters or links to them when asking a question like this.
If parameters are unable to be found, it's likely that no recommendation can be made.
edit: given they are triaxial, they probably won't suit any of Bill's designs...
achille49
Re: Heathkit AS-27
#3 Post by achille49 »
AS-27 parameter :
Z : 8 ohms
Sens : 98.3 db
Re : 6.7 ohms
Le : 1.66 mh
Vas : 8.557 cu ft
Qts : 0.385
vb : 7.5 cu ft
Fb : 40 hz
F3 : 42 hz
Ql : 7.0
achille49
Re: Heathkit AS-27
#4 Post by achille49 »
Do you have a BFM speaker design recommandation?
Re: Heathkit AS-27
#5 Post by Bill Fitzmaurice »
Grant Bunter wrote: Sat May 04, 2013 3:39 pm given they are triaxial, they probably won't suit any of Bill's designs...
+1.
