Sombody Help! Capacitors for DR250
cave
#1 Post by cave »
Finding 250v 20uf where I am is a hell. The closest i have come is 250v 15uf. Will this pass for the compressing driver filter? What would the side effects be if any. I'm desperate to complete the wiring by this evening.
Built 2 x DR 250
Building 8 DR 250
Built 8 x OTOP 12 JARRAY
Built 2 TITAN 48
Re: Sombody Help! Capacitors for DR250
#2 Post by Tom Smit »
Are you able to get two 10uF caps, instead? Or one 15uF and one 5 uF?
Israel
#3 Post by Israel »
where's your location
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
cave
#4 Post by cave »
I live in Ghana in West Africa. I was told by the vendor that he has the 10uf. How do I use that?
Built 2 x DR 250
Building 8 DR 250
Built 2 TITAN 48
Rune Bivrin
#5 Post by Rune Bivrin »
Connect them in parallel.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
Chris Betancourt
#6 Post by Chris Betancourt »
Do you know how to connect them in parallel???
This is parallel
And this is series
get a good clean solder on them.
Christopher Betancourt
Authorized Builder
Puerto Rico
All running w/SAC or DL1606
On the table:
too much work!! LOL
Future:
cave
#7 Post by cave »
Thanks guys, The project is turning out great I'll soon post my pix.
Built 2 x DR 250
Building 8 DR 250
Built 2 TITAN 48
cave
#8 Post by cave »
I have the 20uf capacitor wired in series to my compression drives. I hear this spike in the compression driver when I switch on the amplifier to my Otop12 Jarrays. What could this be, and is it normal?
Built 2 x DR 250
Building 8 DR 250
Built 2 TITAN 48
byacey
#9 Post by byacey »
You'll still hear the turn on thump of the amplifier, but the capacitor filters out much of the low frequency content, so it results in more of a high frequency pop. Most newer amplifiers mute the output until the amp stabilizes during power up.
T48s
WH8s
SX212
