It is currently Fri Sep 10, 2010 3:25 pm
View unanswered posts | View active topics
Wi's Driver Showdown, JL 13w1v2 vs. Dayton 15" DVC in 24"THT
| Author |
Message |
Drey Chennells
Joined: Sun May 17, 2009 10:12 pm Posts: 485 Location: Orlando,FL
 Re: Wi's Driver Showdown, JL 13w1v2 vs. Dayton 15" DVC in 24"THT
Wi so you had the access door open all night on the DVC? Do you think it could have coped with the power all night if it was closed?
_________________ Dragonfly Design Group Authorized BFM Builder/Consulting/Acquisition http://dragonflydesigninc.com/
| Sat Feb 06, 2010 8:46 pm |
WiSounds
Joined: Thu Feb 07, 2008 3:58 pm Posts: 1187 Location: Rochester, New York
If I had put the access cover on, I bet it would have fried.
_________________ myspace.com/wisounds
140 at 20 cycles.
| Sat Feb 06, 2010 8:51 pm |
Drey Chennells
It sounds like you pushed it hard, 950 watts. You think the driver was reaching a mechanical failure at all then or just electrical overload? I'm just wondering if extra cooling trumps rear chamber damping/protection. What you think? Drey
| Sat Feb 06, 2010 9:01 pm |
wr_anders
Joined: Thu Dec 17, 2009 12:53 pm Posts: 121 Location: Oklahoma City, OK
What about using some copper stick-on heat sinks? Like these: http://www.xoxide.com/enzotech-bmr-c1.htmlJust use some thermal adhesive, peel of the label on the driver and put them there. They're only 14mm (1 3/4") tall. Do you have that much clearance? Edit: They also make some that are low profile, 9mm (9/16")
_________________ If you can still see clearly, there's not enough bass.
Done 33w dual-DVC THT
| Sat Feb 06, 2010 9:10 pm |
WiSounds
No mechanical failure, just alot of heat. Bill says that really anything over 500w is a waste anyway. I kinda wanted to see how much abuse the thing could take. If I ran a pair of DVCs off one FTX te power levels would match a bit better, but the prob with that is getting the right impedance.
One thing that was nice about having the covers off is I could monitor the status as the night went on, every once in a while I popped in the corner to check and see how toasty things were. The only time I noticed an abnormally warm condition was when I was breaking down after my set. The rest of the night they ran warm but not hot.
Hadn't thought about heat sinks, but again this was hopefully a one time worst case scenario. I wanted to push the driver as hard as I could to see what would happen before I trust them in the next phase of my rig.
140 at 20 cycles.
| Sat Feb 06, 2010 9:14 pm |
la malta
I like these DVCs. I was excited about the Lab 15 mistakenly thinking it would handle more power, not realising the spec on the PE website for the DVC was for each coil, with a 600w RMS total for both voice coils being the same as the Lab. Series wiring the VCs for a 16ohm load per driver means more subs off one amp. Plus they are cheaper. I'm nearly sold.
| Tue Feb 09, 2010 1:46 am |
WiSounds
If it survived a 3am drunk set from me, they get my endorsement. Lol
140 at 20 cycles.
| Tue Feb 09, 2010 7:44 am |
Drey Chennells
Riight..
| Tue Feb 09, 2010 12:48 pm |
la malta
"Stella Artois Certified"
| Tue Feb 09, 2010 1:25 pm |
phil
Joined: Mon Feb 02, 2009 2:36 pm Posts: 152 Location: arcata, ca
lmao. Do you're drunk sets end up with the lows slammed as close to 6oclock as the knob will allow when you get excited?
| Tue Feb 09, 2010 8:59 pm |
WiSounds
Nah bass only gets the 1 or 2 oclock treatment. What I tend to do is say "hey the system has been running fine all night, why not open up the limiters a cpl db!"
140 at 20 cycles.
| Tue Feb 09, 2010 9:41 pm |
WiSounds
Seems the DVC didn't fare as well as I thought. Spider is ripped and she kicks the Ashly amps into protection now. Worked all night till I unhooked it, then sat for a couple of days before I noticed it today. So needless to say the DVC can run at 1kw for only one night. I'll get pics and stuff up in the next few days. Glad there is a 5-yr warranty.
140 at 20 cycles.
| Fri Feb 12, 2010 5:27 pm |
Drey Chennells
noted.
| Fri Feb 12, 2010 6:59 pm |
wr_anders
If you had more of your cabs loaded with the DVC, would you run them as hard as you did the one?
| Fri Feb 12, 2010 7:05 pm |
James R
Joined: Mon Jul 31, 2006 7:49 pm Posts: 529 Location: Upstate NY
I was over at Wi's this evening and even though the spider was ripped it was still working as he set up a couple to demo them for me. My pant legs were shaking very impressive, I'll let him tell the rest
_________________ " Everyone Has a Photographic Memory, Just Not Everyone Has Film In The Camera"
4 x T48 24.5" 3015LF 2 x DR280's
Work in Progress: 8 x 112 Otops
| Fri Feb 12, 2010 7:11 pm |
Who is online |
Users browsing this forum: No registered users and 1 guest |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
