It is currently Fri Dec 15, 2017 4:42 pm
Post new topic  Reply to topic  [ 7 posts ]
Author Message
 Post subject: Vibration/Loose Brace
PostPosted: Fri Oct 20, 2017 11:38 pm
Offline
Hello to all,
I finished the build of 4-dual loaded T60's and I am more than pleased. Formal review to follow. One of the cabinets unfortunately has a noticeable vibration/rattle/ from maybe 50hz and up. All the braces in the mouth seem secure and stable. I put a glass bottle on top of a functioning cabinet and the bottle does not move, put the bottle on top the cabinet with vibration and the bottle jumps and moves around. Is there anyway to identify what brace may be loose? If it is brace 2/8, does the force/movement on panel 8 indicate it is loose on the 2-panel or 8-panel? To find the location of the braces I envision plunge cutting perpendicular to the brace line at the front of the cab and rear to determine the CL of the brace, screwing, sealing, painting...assuming the brace is loose on panel 8.... If it is on 2 that might be a little more difficult.. Long winded but looking for solutions or ideas...
Also, so much respect Mr. Fitzmaurice for designs and respect for all that build any of these cabinets. All the effort was worth it once I heard them sing...Unbelievable. I have been to indoor venues with 40+ PK CX800's, and I am more than pleased with the sound quality and output.
_________________
4xDual-30” Tuba 60’s
1x20” THT
Top
PostPosted: Sat Oct 21, 2017 1:13 pm
Offline
Lay it on different sides and stand on it to see where it stops rattling. If you find it then drive some screws in the braces and or panels. Good luck. I had to demolish one because I couldn't find the rattle.
_________________
2x SLA's 6-5" mids, 9-gt-302's
OT12 flat array
Top
PostPosted: Sat Oct 21, 2017 6:34 pm
Offline
Update! I tried “listening” all over for the vibration but no real luck. I decided to pull one driver so I could hear or see something better. I pulled the driver and let the other driver play a test tone, then I pushed down on panel 3 and it instantly went away. Upon further inspection the middle 3/6 brace was loose, really not loose...but you can feel the glue seam separated. When I mounted a driver, I used a lag type screw and when it passed through the mounting blocks it barely touched the middle 3/6 brace creating a push pull effect. I noticed this when I was torquing them down so I ground off 3/8” so it didn’t protrude...but damage was done. Good news, easy fix with some PL and screws from the chamber and access/storage chamber.
Lesson learned, pay close attention and document brace installation or be consistent with measurements...just in case you have to come back and put screws in braces blindly or maybe put a couple in just to establish the line. For how much time goes into these cabinets no shortcuts should be taken. I built all four methodically at the same time to in a stepped type construction. I felt like rain man with the planning and construction sequencing AND I still wished I would of done some steps differently... I will submit somewhat lengthy build post soon. Thanks for the reply!
_________________
1x20” THT
Top
PostPosted: Sat Oct 21, 2017 10:12 pm
Offline
Good to hear it was an easy find & fix. I can only imagine how stressful that would be thinking about ripping it open.
_________________
2 x 21" T30's with Lab12's
2 x 28" T30's with Lab12's
Top
PostPosted: Sun Oct 22, 2017 9:21 pm
Offline
:clap:
_________________
Top
PostPosted: Wed Oct 25, 2017 3:36 pm
Offline
Is that just your user name, or are you really in SoCal?
_________________
Top
PostPosted: Fri Oct 27, 2017 1:12 am
Offline
Looking forward to this... :clap:
_________________
2 x TAT
Top
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
banner
Powered by phpBB® Forum Software © phpBB Limited
